Charging harness diagram, FC
Hey all so I got my new project home the other day and started taking it apart. I know factory wiring isn't worth a **** anyway but I figured if it was in okay shape I'd use it for the time being. Low and behold theres some sort of donkey immobilizer and alarm hacked into it so I pulled it out. I've got an 8 circuit kit on the way to power lights, fuel pump, gauges, fan, ignition and whatever else I need to get wired up. However when ditching the fc harness I need to know what do as far as making a new charging harness.
The engine set up is a 1jzgte, which shouldn't matter because the OEM fc harness will run the 1j and it's alternator.
Does anyone have a crude diagram drawn up or would you be willing to make one? Here's one I did and I would appreciate any guidance you could offer. Thank you
Red is the hot side.
The big 4 gauge cable goes from Battery directly to starter. The charge wires is spliced to feed under hood fuses. The Ignition power comes from the under hood fuse box. The signal wire goes to the starter.
The way your illustration is drawn, it looks like you have the Main cable going to the ignition switch and powering up the starter
