Oil cooled turbo - What to do with factory coolant lines
Old Feb 11, 2012 | 11:07 PM
jhammerrx7's Avatar
I Like Guns
SD Oil cooled turbo - What to do with factory coolant lines
Hey guys, I have a PT6266 non-bb on the way and it's an oil cooled turbo only.
I need some suggestions or input on what to do with the factory supply and return coolant spouts coming off the water pump/thermostat housing.
Found a couple of threads were other members suggested welding the spouts shut.
I don't necessarily want to weld the spouts shut or do anything permanent.
What do you suggest I do, or what have others done in this situation?
Any pics or instruction would also be greatly appreciated.
Thanks, Josh
Old Feb 12, 2012 | 02:33 AM
rxspeed7's Avatar
F-IT
Tap for 1/4"Npt and 1/8"npt and put plugs in place
Old Feb 12, 2012 | 10:44 AM
theorie's Avatar
AponOUT!?
Run a watercooled wastegate like the tial MV-S or MV-R and you can use the coolant in/out to the wastegate.
Old Feb 13, 2012 | 09:53 AM
jhammerrx7's Avatar
I Like Guns
Thanks for the input guys.
I picked up a 1/8 NPT and 1/4 NPT plugs and taps.
How do you normally go about tapping and plugging the nipples?
Do you completely saw off the nipple back to the block and tap it there?
Or would there be any issue with just tapping the end of the nipple without sawing or removing the nipple?
Thanks again, Josh
Frisky Arab
13
Aug 18, 2015 05:30 PM
Kyo
Aug 14, 2015 02:00 PM
