Help me identify this Brake Master Cylinder
Old Feb 9, 2012 | 12:03 AM
Mushiki's Avatar
Rotary Lover
Hi everyone,
My FC's Brake Master Cylinder is failing, and I can't seem to find the exact replacement for the one that came with my car...
Mine is a NA FC, 4pot Front Brakes, ABS, AAS, and vented discs.
Here you have a couple of pics of the unit itself
I already got two different new ones, but they don't match this one... got one from a S4 T2, and one from a S5 NA... no luck
Can any of you guys help me identify the one pictured?
Thanks in advance!
Old Feb 9, 2012 | 01:26 AM
tom0261's Avatar
Try RockAuto.com; looks like they may have 4 to chose from: Wagner, A-1 Cardone, Cardone, and Raybestos.
Good luck.
Old Feb 9, 2012 | 08:51 AM
Mushiki's Avatar
Rotary Lover
It does look like a S5 Turbo one... right?
Old Feb 9, 2012 | 09:24 AM
JerryLH3's Avatar
Rabbit hole specialist
Your car has an interesting array of features, being N/A but still having ABS. It sure does look like an S5 Turbo master cylinder to me. The outlets are in the correct location, and there are only two of them.
Old Feb 9, 2012 | 10:15 AM
Mushiki's Avatar
Rotary Lover
Interesting? Don't even get me started...
S5 NA body
S5 Turbo brakes w/ABS
AAS
S4 6-PI Engine
Butterfly-valve style Aux Ports, actuated by a solenoid
S3 Electronic Distributor
Thermal Reactor
and the list goes ooon...
Old Feb 9, 2012 | 12:17 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
I thought ABS master cylinders had an opening on the bottom for the ABS pressure switch. I've never seen an FC with that shaped reservoir before...?
Old Feb 9, 2012 | 12:58 PM
Carzy Driver's Avatar
Law Breaker
I thought all FC master cylinders were cast iron, that looks like aluminum.
Old Feb 9, 2012 | 01:23 PM
RW-7's Avatar
Moderating the Trochoid
What does the booster it came off of look like? You have a pic of that too?
Is there a stamp on the bottom of the cylinder like 15/16?
Old Feb 9, 2012 | 02:44 PM
Law Breaker
A pic of the brake booster would deffinity help, I'm thinking the PO might have done a booster / mc swap.
The1Sun
Sep 15, 2015 04:45 PM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
