Best way to remove OMP/MOP plastic lines
Old Feb 8, 2012 | 09:41 PM
Captain_Panic's Avatar
Back in the BOOST Game
In the middle of a little winter project and I need to remove the OMP lines. Not quite sure how they come off. It looks like i can just pull and twist, but it seems to be a bit harder to do that. Instead of forcing it, I thought I would ask, how do these little buggars come off the injectors?
Thanks,
Don
Old Feb 8, 2012 | 09:57 PM
Hey Don,
you're asking about the injectors on the top of the rotor housings?
If so, you need to use a 19mm wrench to loosen and remove the injectors, the lines terminate in a banjo fitting underneath the injector. If they're your original lines, definitely a good idea to replace them with new OEM pieces or aftermarket stainless steel.
HTH
Old Feb 8, 2012 | 10:00 PM
Ah! Thanks Rich.... NO wonder I could find details in searching in how to pop these babies off.
Frisky Arab
13
Aug 18, 2015 05:30 PM
Leeroy_25
Aug 17, 2015 12:53 PM
