Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
s4 213,000 miles dyno
Old Feb 6, 2012 | 08:11 PM
mario1386's Avatar
mazda mario
FL s4 213,000 miles dyno
ok my car has 213,xxx miles on the motor and chassis. I went to dyno meet on saturday and I decided to put the car on the dyno.
mods;
pacesetter header
obx-r 3in exhaust
emission removed
efans
11.7lb flywheel
exedy clutch
t2 drivetrain (tranny & diff)
k&n drop in filter
Old Feb 6, 2012 | 09:52 PM
lastphaseofthis's Avatar
My job is to blow **** up
mods;
pacesetter header
obx-r 3in exhaust
emission removed
efans
11.7lb flywheel
exedy clutch
k&n drop in filter
seems kinda high if you ask me... i'd like to see compression numbers from an engine with that many miles on it..
Old Feb 7, 2012 | 10:35 AM
rotormind's Avatar
R u sure thats the original motor?
Old Feb 7, 2012 | 12:20 PM
fidelity101's Avatar
Rallye RX7
Dynojets always read high
Old Feb 7, 2012 | 04:00 PM
grantm3's Avatar
Mustang dynos always read high... lol
Old Feb 7, 2012 | 04:14 PM
rxspeed7's Avatar
F-IT
^ your theory is wrong. Mustang dynos always read lower. Trust me, use one almost everyday. Usually dynajets figures are very close to flywheel hp.
Old Feb 7, 2012 | 07:49 PM
mario1386's Avatar
mazda mario
Compression is at 110 psi all sides , and yes it is the original motor; i am the second owner of the car
Old Feb 7, 2012 | 07:58 PM
mario1386's Avatar
mazda mario
Dynojets are inertia based, the computer knows exactly to the ounce what the dyno drum weighs, ours is a shade under 3000 lbs. Than it knows drum rpm vs. time. And takes a tach signal from the motor and instantly calculates the gear ratio. Knowing exactly what rpm the motor is at, exactly what the rpm vs. time the drum is at, and how quickly it accelerated that fixed mass (drum) it calculates Horsepower and Torque. This is how all Dynojets work. Now in the shop I have a brake that attaches to the dyno that can load the drum even higher to hit different map regions while tuning.
Most mustang dynos and the like use smaller much lighter drums. Load MUST be applied to do any dyno test. You must enter wheel size, estimate the weight, and other variables and program the dyno accordingly so it can apply load. Thats why they suck for repeatability. People will argue but it's true. If you want to do comparisons, you have hope the operator programs it exactly how it was previously. Every shop that DOESNT have a dynojet has to sit there and rationalize and explain how and why their dyno is better. Most even have sections of their website devoted to it. In the end, it's ET and other things that tell the true story. Dyno's are nothing but a tool, it's a big expensive torque wrench.
Old Feb 7, 2012 | 08:00 PM
mario1386's Avatar
mazda mario
Dynojets are known to read about about 15% higher than most L&S, Mustang, DD dynos. 15% is about what most people use as a rough drivetrain loss. So a good estimate is that Dynojet numbers= flywheel hp. It doesnt matter what the number is, as long as you can see the change.
that depends who setup the Mustang or DD dynos. They vary operator to operator. Day in and day out we dyno brand new 2011-2012 Mustang GT's, they advertise 412 at the flywheel, and they ALL make about 360 (wheel) bone stock. GT500's advertised 500hp, and make 440-450 (wheel) day in and day out here. We had a 370z that made exactly what it was supposed to down to the single hp. We had a Powerstroke diesel truck that made 605/1070 on another dyno and 602/1081 on ours yesterday. We had a turbo 350z that made 10 LESS hp on our Dynojet than the Mustang dyno it was tuned on 2 weeks before. Bring me this car a month from now it'll read exactly the same hp. Thats why it's the industry standard. It's repeatable and accurate.
Old Feb 7, 2012 | 08:02 PM
mario1386's Avatar
mazda mario
this was arguement that i had in my facebook cause some honda idiot didnt believe a 200,xxx mile motor still have that kind of power
Old Feb 19, 2012 | 12:20 AM
farberio's Avatar
NASA-MW ST4
I am pretty sure its because the dynajet dyno tries to spit out the flywheel hp, I believe it has a correction factor in order to do that.
Old Feb 20, 2012 | 10:24 AM
Starfox07's Avatar
Environmentally-Hostile
The torque curve falls off pretty hard after 6,000rpm. Are your 6 ports functioning?
Old Jun 9, 2012 | 05:49 PM
mario1386's Avatar
mazda mario
^ i have the aux wired open
Old Jun 9, 2012 | 06:56 PM
jorx7's Avatar
that power seems right, good for a motor with that type of mialage. just get a racing beat header! and junk that pacesalsa crap!
Old Jun 10, 2012 | 09:46 AM
rx7freak13v's Avatar
ive been running a pacesetter header for quite some time now. i love it. the bends are more relaxed than the rb one and it is already collected. so i don't have to buy the collector or have one custom made. it's a really long tube header that i have, longer than the rb ones that i've seen, unsure if rb sells one as long as the pacesetter one i have? anyhow, i got it in a deal and am very happy with it. there is a reason why these guys are still around. however, my new engine is going to need much much much longer primary runners so i thought about a custom one copying the pacesetter but with larger diameter. anyhow, the point is, is that the pacesetter isn't bad. i would buy another one, in fact i did buy a second for my brothers fc and have a third one sitting at my house chilling out lol. they are easy to find in good shape and really cheap.
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Turblown
Aug 14, 2015 04:48 PM
Clacor
Aug 14, 2015 09:17 AM
