Time attack 1981 RX-7 with M2R 13BPP Build
A litte bit of my engine first. First build this engine back in 2003. at that time. i was building a
SCCA ITE club racing car.
did few years of racing. I decide let my self pull togeter ( spending way too more )so i keep
my car to storge
The engine make 320HP at 8500RPM at MAZDATRIX's engine with GenBerg 58 IDA
Quick spec
T2 base 13B PP with new T2 housing, new 9.7 rotor. balance . with PP housing design by locoal racer in my area at tha time (SCA)
Because all the experince i learn from my 13B PP.... I decide I need a car that is easier to drive
and easier to take care. so i build a 13B Stock port 1981 RX-7
]http://youtu.be/Arw9a5nGiQY
it was pretty fun to develop this car, and i learn a lot from how to set up the live axle design car
but as you know. that is only so much you can have from almost stock engine. I try to keep up with modern rivel. but that feeling sucks when you can out brake them and out corner them but loose at back to straight way....
So after few mouthof debet i finally decided to pull my PP out from the storge. and decide to take it a full rebuild( since is sitting for almost 6 years)
here is what i will use
MOTEC M2R never have experience with motec before. hopely it will be a good one
TWM 58 IDA style throttle body. Is a littble big for my RPM use( under 8500)
Dynamic injector 2200. Keep it simple by just using 2 instead of 4
if any one of any common and thought. please post it. i need all the brain power as i need it
since me and my rx-7 is all the way at asia already. i dont have that much resource like i used too
REgard
J
my car to storge
Quick spec
REgard
J
Finally Tearing engine part by my self at my friend's shop( he was too busy working on other customer at 12am )
A bit nervous . because you never know. what happend when you let engine store for 6 years and this engine was build back in 2003
and this engine althought is build by my good friend at his workshop. and he is a long time rotary racer
and BMW instructor At SCA
At that time i use Brand new housing, Rotor.. new gear almost every thing is new
When he assemble this engine for me back in 2003, he told me leave him alone. because i will bother him..... I was like WTF
When i first crack it open. i feel relief . because this engine seen to like in very good condion
The engine did not have those crazy port. i think this is same port That" 7's only racing" use
There is machine mark on the rotor surface and a balance hole. meaning is been balance and ok to rev to 8500RPM and above
Oil mod on shaft. i remember i order a oil jet last engine rebuild as well
there is not too much wear on apex seal either. i think the burn mark in the middle of seal is from
loose clearance ( I heard thi is can engine to seal better at high RPM)
I am wondering how loose(clearance) of spec i should build for this PP motor. I get some spec from RB website
but that is only for carbon apex seal, how about other spec ? according to factory ? on loose side ?
thanks in advance
thanks in advance
Dig it from the Race car section this is my 13B PP dyno thread back in 2005
https://www.rx7club.com/showthread.p...eral+port+dyno
Trending Topics
some update of my project
since engine is so clean. clean the parts was pretty easy
after assemble the parts find out. my FC oil pan baffle did not fit !!! thinking to build a oil sump
spacer with baffle
Engine should be in to the car soon. here at taiwan, lock of Rotary support meaning i have
machine every parts that i cant buy it like i used to in state
and last , why i am change engine. here is my poor stock sepc engine blue print by Tri-point.
from 1997. you will suprise with apex seal worn to this stage, engine still start(but will took
about 30sec-1min at cold), but once engine warm out the car will be fine, will not eat engine oil
and other thing, however will develop a miss fire during high RPM
spacer with baffle
Some update for the project
Engine still not into the chassic yet.
Machining the new pulley
putting new side mount bracket for the car
will keep the project update if any thing new happend
some more update of the project
Finally engine is into the bay
redrill the engine mount to make engine sit more straight hope it willl improve drive train loose
putting two FC cooler to cool my 13B PP
Testing my new diff cooler pump. i am getting tired of change final drive.. this is my 6th set.. hope wit cooler. will be my last
finally decide to insall rear coilover in my car also.
Man this chart is great. Thanks for posting it. I think it explains some of what I have been seeing with my car an intake.
My 4 throat ITB setup runs different diameter pipes and different length runners. If you take the outer Bridge Ported runners, they are 49 mm I.D. and run 13.25" from face of block to mouth of the intake bell. Both of these dimensions relate to a power peak of approx 8,500 - 8700 rpm. The Bridge Port outers will support that rpm as well.
My Inners or Primaries are a 40 mm I.D. and run about .5" longer as they are on an angle, so that would put them at just about 13.75". These measurements are on the bottom or longest side. I may actuallt be about a 1/4" shorter as a mean length. This length should give a H.P. peak around 8200 rpm if you can extrapolate these things from the chart. The car is running a pretty big street port on the primaries, so that should support the flow as well.
The car has a really broad torque curve and pulls easily all the way from about 3,500 to over 9,000 rpm. These charts are the first ones that put everything together. Great find and it puts my mind at ease somewhat. Thanks a ton.
My only concern is where does the measurement start and where does it end? In my case I am measuring from the mouth of the bell lip to the plate surface that bolts to the engine.
Eric
Eric
Here is the complete page:
Judging by the picture it should be measured from the trochoid surface, so you should probably add 1.9" to your intake length to be able to compare them
MM. my intake manifold is on long side that i notice
but it all come down to the exhaust set up also
here is some more update for my intake !!
Hope all this small detail can improve my overall performance
but yes getting all the details right will really improve things.
I am using LS2 truck Coil.... was suprise how hard to get it at ebay. seen to be every one want this type of coil
Engine in. finish air filter and intake manifold . and building custom tower bar
Some update
The first race will be jun 17. but... the engine is not fire up yet. so i cam pretty much in deep ****
the car is strip out at rollcage shop for the rollcage i am build a simple cage that will meet FIA
stander. not those fancy time attack or rally cage. which is too hevey for my project
here is one of many custom part from my car.... Tri bar for engine bay took very long time to build
but end result was pretty good
