Power steering rack and pump. 2 line rack with 3 line pump
Old Feb 5, 2012 | 01:42 AM
noGoodNolan's Avatar
soooo... here i am.. i busted the seal in my FC it HAD a 3 line pump and rack on it...... searched and only rack i could find was a 2 line. so i went ahead and ordered the mazdatrix bump steer and high angle tie rod spacers.... decided i would block off the top line coming out of the pump. which was the extra line that wouldn't be hooked up on my 2 line rack.... my question is... would this be hurting my pump... and if not with my power steering be working normal. i test drove it... and i think it needs an alignment.. cause going straight it feels like the tires are fighting against each other. kind of hard to turn....BUT after i turn a little bit.. the car will shoot over like it is turning really fast all of the sudden.... someone help me out, explain... is the extra line being blocked off doing this or does it just need an alignment. and will the line being blocked.. hurt anything... thanks for your time.
sorry for the bad sentence forming please forgive me
thanks, Nolan
astrum
24
Nov 15, 2017 08:44 AM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
