Boost goes up with rpms?
Old Feb 4, 2012 | 06:07 PM
junito1's Avatar
F**K THE SYSTEM!!
I recently went to the dyno. I have a hybrid s5 turbo. THe boost would rise with the rpms. Peak boost was at redline. The boost graph was a steady slope to redline. What could this be?
Old Feb 4, 2012 | 06:14 PM
rxspeed7's Avatar
F-IT
Was it overboosting or just would take till redline to make what the wastage is set at?
Old Feb 4, 2012 | 06:27 PM
junito1's Avatar
F**K THE SYSTEM!!
overboosting. WHat ever internal actuator BNR uses was hooked up directly and it was seeing 19 psi.
Old Feb 4, 2012 | 06:49 PM
rxspeed7's Avatar
F-IT
More than likely the waste gate is insufficient with hold boost at the desired pressure. It's a common problem that has plagued all factory turbos. I recently built a car with a stock upgraded turbo that wouldn't for the life of it hold steady boost.
So what I did, put a external waste gate on the factory manifold. Lol.
You can try porting the stock waste gate holes in an effort to help.
Old Feb 4, 2012 | 06:58 PM
arghx's Avatar
rotorhead
Did you buy this turbo new from BNR? Has anyone adjusted the wastegate arm tension at all?
Old Feb 5, 2012 | 03:27 AM
BLUE TII's Avatar
Rotary Motoring
I had the same issue with my S5 based BNR Stage 4 hybrid turbo.
Went with ported wastegates and clipped "P" trim wheel- still boost creep
Open air vented the stock wastegates- better but still boost creep.
Adapted 60mm external wastegate with wastegate passages ported out to max casting allows- still some boost creep.
Ported out the manifold and exhaust housing runners to eliminate the velocity stacks and make flow favor the wastegate instead of the turbo- fixed boost creep.
Instead of all this work, I would advise putting a restriction in the exhaust as far back as possible to limit flow and so eliminate boost creep.
Japanese tuners put a "gasket" of thick metal with an undersized hole in it at the joint right before the mufflers.
Now that you fixed boost creep, start saving for a full single turbo kit if you absolutely need more power.
Old Feb 5, 2012 | 03:31 AM
BLUE TII's Avatar
Rotary Motoring
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/most-modified-stock-turbo-how-stop-boost-creep-221849/page2/
This old thread of mine-
Old Feb 5, 2012 | 09:48 AM
junito1's Avatar
F**K THE SYSTEM!!
Originally it was a hybrid some other company made. Then i had sent it to BNR and i spent a good bit for them to rebuild it to their standards which include using a new exhaust housing from a stocker. YEs it is a P-trim exhaust wheel one.
I was under the impression boost creep happened right after peak torque right as the turbo spooled up then would loose psi at red line... Mine was the opposite. HAd like 8 psi at 5k rpms.(really?) and from 5k to 8,200 it sloped up to 16-19 psi.
Old Feb 5, 2012 | 10:29 AM
Liborek's Avatar
Boost creep will happen always when wastegate can´t divert enough mass flow. For the amount of money which probably went into modifying stocker, you would be better with full T04E 60 trim on tubular manifold with huge room to grow.
Hybrids are just too big compromise IMO. Never ending battle with boost creep by modifications which compromise spool up and consequently denying purpose of small hotside...
Old Feb 5, 2012 | 12:45 PM
rxspeed7's Avatar
F-IT
Here was my fix for a car I built to eliminate boost creep. I agree though after the time and money could've went with a nice aftermarket setup.
Old Feb 5, 2012 | 03:46 PM
arghx's Avatar
rotorhead
You may need to adjust the tension in the wastegate arm. Even then if that is not a factor here, you would probably be better off just having a high flow cat welded in.
Old Feb 5, 2012 | 09:36 PM
junito1's Avatar
F**K THE SYSTEM!!
Wastegate armbis fully extended. And I have a full 3" Turbo back.
Old Feb 21, 2012 | 03:06 PM
Fleemer's Avatar
Waste gate is too small dude, even if you port it.
IF you port it too much, you'll lose manifold pessure because the wasgate will crack open just from exhaust pressure. You're reaching the limitations of the stock turbo.
I'm happy with my boost spikes (its tuned for it :P)
Old Feb 21, 2012 | 03:27 PM
Turblown's Avatar
Turn up the boost
I've done the same thing in the past, rock solid boost control then...
Rotary Performance Parts
Old Feb 22, 2012 | 12:40 AM
rxspeed7's Avatar
F-IT
Works flawless now!!!
Old Feb 22, 2012 | 09:24 AM
SirCygnus's Avatar
whats going on?
just with a single runner?
Old Feb 22, 2012 | 09:52 AM
rxspeed7's Avatar
F-IT
On a s4 manifold its open outlet. On a s5 however you have to either run 2into1 or put your pipe in the center of the divider so the sides are split for the wg runner.
Old Feb 23, 2012 | 10:25 PM
rxspeed7's Avatar
F-IT
about what.............. it helps if you include what your curious about
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
