Help. Taking off carb and need help
Old Jan 29, 2012 | 05:55 PM
lawless1's Avatar
I am able to get my 85 GSL to run, but it floods out constantly. It sat nearly 5 years before I got it and I am trying to get carb off for a rebuild. It seems like a float is sticking because it will run for a while and then flood out. I have de-flooded it many times and changed oil after a few de-floodings and had gas in the oil. I am to point of pulling out the four bolts that hold carb on, but can't get to bolt heads. I know I am an idiot, but what tool did any of you folks use to get to those bolt heads???? Could there be something else besides a stuck float causing it to flood so much?
yetter227
20
Sep 5, 2015 11:57 PM
