Confusion about compression normalization
Old Jan 29, 2012 | 05:30 PM
Brigdh's Avatar
I just ran a compression test with a borrowed TR-01 on my S5 TII and came to two different normalization numbers. Would someone please help me figure out what I did wrong?
For the front rotor, my raw numbers were 81 - 83 - 81 at 273 rpm. I'm at 5430 ft above sea level.
According to the compression calculator at foxed.ca, my normalized numbers are 62.07 - 63.60 - 62.07
Running the calculations by hand, I got 94.225 - 96.225 - 94.225
So, clearly one of the results is wrong.
How I figured it out by hand (so someone can point out my mistake):
Looking at the graph on C-7 for RPM compensation, it looks like at 280 rpm, an 85 psi normalized will actually register as 92.5. So, for every RPM over 250, I should subtract 0.25 psi (7.5 psi gain / 30 rpm gain), or 5.75 psi for my 273 RPM.
That brings my RPM adjusted numbers to 75.25 - 77.25 - 75.25
Now to adjust for altitude. The next graph indicates that an 85 at sea level will register a 71 at 4000 ft above sea level. That comes to a 0.0035 psi drop per foot above sea level. So I added 19.005 psi (0.0035 psi loss per ft alt * 5430 alt).
My final numbers are 94.225 - 96.225 - 94.225 which are about 30psi better than the online calculator.
Since that is the difference between a great engine, and one that needs a rebuild soon, did I screw up my calculations?
Old Jan 29, 2012 | 06:54 PM
Brigdh's Avatar
After looking things over trying to figure out what was wrong, I ran the numbers through the online calculator again and got a more reasonable 96.82 - 99.21 - 96.82
I must have typed something wrong in the first time to get the low numbers. So, yeah. Clearly user error
Old Jan 29, 2012 | 10:44 PM
misterstyx69's Avatar
Retired Moderator, RIP
I calculate that you are just "calculating" too much!
With Numbers like that I would be signing off the internet and heading out to drive the **** out of the car!.They are Fine!
Old Jan 29, 2012 | 11:31 PM
SpikeDerailed's Avatar
This sh*t burns oil!
Are rotarys not hard to start up there?
Old Jan 30, 2012 | 12:03 AM
Brigdh's Avatar
Once and a while I've had a hot start flooding issue. Never had any cold start issues.
R.O.D
34
Jan 6, 2016 12:09 AM
risingsunroof82
Sep 9, 2015 08:06 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
doritoloco
Sep 5, 2015 12:41 PM
