Rack & Pinion Steering
Old Jul 22, 2002 | 10:25 AM
AdamAnt's Avatar
Has anyone heard or seen of anyone modifying a first gen with rack & pinion steering?
Does anyone think that it's possible?
Old Jul 22, 2002 | 10:54 AM
MikeLMR's Avatar
'Last Minute' Rallying
I think its one of the first things to cross many a 1st gen owners mind
try searching I think people have had lengthy discussions about this already
Mike
Old Jul 22, 2002 | 12:11 PM
peejay's Avatar
Old [Sch|F]ool
Contemplating it.... Won't be easy though!
I need to find a rear-steer car with 22" between the inner tie rod pivots. That will get us the rack. Then need a way of attaching it to a 1st-gen steering column (this pretty much requires hunting down a '84-85 power steering car's column). Then, to properly mount the rack to minimize bump steer, a custom oil pan needs to be made, and the engine needs to be raised a bit (about 1/2-1 inch is as far up as we can go before hood clearance is a big issue) so the rack clears the bottom of the engine.
Basically it sucks Some people have swapped FC crossmembers in 1st-gens - this allows use of the FC front-steer setup and requires the use of FC struts and knuckles (allowing use of the bigger FC brakes) but so far I've seen no details on what they do for engine mounts, and the ones I have seen have used the FC steering column (yuck).
Old Jul 22, 2002 | 12:30 PM
j9fd3s's Avatar
Community Builder
the millen rally cars use rack and pinion in the 80's, but now that i think about it they used the whole 626 front suspension too.
mike
Old Jul 22, 2002 | 12:32 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
we should petition Racing beat or Mazdatrix to build a conversion kit. If either one made a kit I would buy it.
Old Jul 22, 2002 | 12:35 PM
peejay's Avatar
Old [Sch|F]ool
it would cost so much nobody would buy it!
Old Jul 22, 2002 | 01:33 PM
jeremy's Avatar
male stripper
what are miata's? i figured with that tight engine bay and their size that they would be a good source.
Old Jul 22, 2002 | 02:41 PM
peejay's Avatar
Old [Sch|F]ool
Miatas are front-steer.
Old Jul 22, 2002 | 02:53 PM
Manntis's Avatar
add to cart
Virtually every production car is front-steer. I think the question was are Miatas rack & pinion, to which the answer is yes.
Old Jul 22, 2002 | 03:12 PM
peejay's Avatar
Old [Sch|F]ool
Actually, for rack and pinion cars, most FWDs are rear-steer (with exception of Subarus) and most RWDs are front-steer.
I was thinking of using a Saturn SC/SC2 rack, which is 12:1 ratio (RX-7 manual steering is 18:1, power is 16:1), excellent feel, no lash (play) at all, and it mounts solidly to the frame with no bushings (Saturns have excellent steering!). But they are 29" center to center, meaning bumpsteer would be a problem. Ah well.
Old Jul 22, 2002 | 03:29 PM
Heres a Idea, what if you got a Jspec right hand drive miata R&P steering system. If you fliped it upside down, you would have a left hand drive rear steer system.
what about that, then you would just need to modify the streering shaft with a CV joint
Old Jul 22, 2002 | 04:58 PM
peejay's Avatar
Old [Sch|F]ool
What's the inner tie rod pivot center to center distance on a miata rack? That's the issue. Any rack we try would have to be 22" c-c.
Old Jul 22, 2002 | 05:15 PM
well, we'll just have to scour the scrap yards with a tape measure.
Where do I measure exactly.
Old Jul 22, 2002 | 05:31 PM
peejay's Avatar
Old [Sch|F]ool
Pivot point to pivot point.
I'm FAIRLY sure the necessary distance is 22"... to be sure measure the center to center distance on an RX-7 center link. When I measured it, I was crawling around in the grass and it might not have been too precise
Old Jul 22, 2002 | 05:33 PM
85RX7GS's Avatar
Did the BMW Isetta have rack and pinion steering? Maybe you could use that.
Old Jul 22, 2002 | 05:38 PM
what do you mean by pivot point.
Old Jul 22, 2002 | 05:40 PM
peejay's Avatar
Old [Sch|F]ool
Where the inner tie rod end pivots... crucial to get the correct length and precisely mount the rack (mounting the rack is the hardest part of fabbing a chassis) in order to get zero bumpsteer.
Old Jul 23, 2002 | 12:46 AM
Jeff20B's Avatar
Lapping = Fapping
peejay, an Isuzu Imark is rear-steer
Old Jul 23, 2002 | 02:22 AM
Manntis's Avatar
add to cart
with the stock recirculating ball loosey goosey steering I get a ton of bump steer as it is.
Old Jul 23, 2002 | 11:55 AM
jeremy's Avatar
male stripper
define bumpp steer for me.
Old Jul 24, 2002 | 09:02 AM
peejay's Avatar
Old [Sch|F]ool
The toe angle changes as a function of suspension travel.
Bump steer is generally a Bad Thing(tm). However it's somewhat beneficial to have a SLIGHT amount of toe out on jounce (suspension compression), especially on a rear-steer car where bushing compression makes outside wheel toe in in a corner. (That's why front-steer is better)
Old Jul 24, 2002 | 12:23 PM
Im going to go to the yard soon, anyonw know the exact size is it 22"?
Old Jul 24, 2002 | 02:40 PM
peejay's Avatar
Old [Sch|F]ool
Looking at it more carefully, I don't think we could realistically put a R&P on our cars. You'd have to make a new oil pan, you'd have to raise the engine, just to make room for the rack. Might have to raise the hood. And then you have to figure out how to mount the rack to the car... have to make a new subframe because you can't attach it to the current subframe - the oil pan is in the way. (If you hacked out THAT part of the oil pan, you'd lose all oil capacity)
Looks like the easiest way is to do the FC front crossmember swap.
I'm sure it could be done with the FB crossmember, but there would be so many compromises that it really wouldn't be worth the effort compared to properly adjusting the existing steering box.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
