streetport question
Old Jan 26, 2012 | 08:36 PM
etinman1's Avatar
MA streetport question
Im looking at buyin an 88 rx7 and the guy says that the engine is rebuilt with a "mild" streetport. My question is what is normal idle rpm for a "mild streetport" because he says that it idles at 1500 and that it is normal for the setup but it seems really high to me.
Old Jan 27, 2012 | 12:12 PM
Alek92's Avatar
rough idle can be a issue that isnt just caused by streetport, they may not know what they have its most likely air in his radiator
Old Jan 28, 2012 | 10:36 AM
Aaron Cake's Avatar
Engine, Not Motor
1500 RPM indicates a stuck cold start thermowax. A mild streetport will have a stock idle of 750 RPM. There could also be a large vacuum leak.
Old Jan 28, 2012 | 10:57 PM
etinman1's Avatar
thats what i was thinking. he also says that he had rteck remove the aws and warm up systems. Y i dont know.
Old Jan 28, 2012 | 11:36 PM
13bpower's Avatar
s4 for life
"aws" is the warm up system. Accelerated Warmup System. Removal is a standard feature of the Rtek and you do want this. Your idle problem is most likely related to the thermowax or vacuum leak as Aaron has stated. Beyond that it could be related to misadjusted cruise control linkage, idle adjust screw setting, or improperly set TPS (throttle position sensor). The Rtek is not the problem.
Old Jan 29, 2012 | 10:47 AM
Aaron Cake's Avatar
Engine, Not Motor
Depending on what he removed when the "warmup" system was removed, he may have simply left the cold start cam in the "cold" position when he hacked up the car.
Old Jan 29, 2012 | 06:30 PM
pheoxs's Avatar
Eskimo
I'm interested in this too, my car has a fairly rough idle with a very aggressive street port (previous owner was building the car as a track car before I bought it).
How would air in the cooling system affect idle out of curiosity?
Old Jan 30, 2012 | 06:58 PM
vl4bad's Avatar
7-Rex
off topic kinda but whats the difference between mild street port and Larger street port...pros and cons of the large street port vs. mild.
Old Jan 31, 2012 | 02:55 PM
13bpower's Avatar
s4 for life
It really shouldn't. The coolent temperature affects the thermowax. The thermowax is designed to bump idle up to aroun 1500 when the car is cold. as the temp of the coolent rises the thermowax lets the idle lower down until a point where it no longer is effecting idle. If you are really having problems with excess air in the cooling system it may be technically possible to effect the temperature that the thermowax is seeing but this is highly unlikely in reality.
Once warm the idle of an aggressive streetport could be rough. This is just like changing the cams on a piston engine. If you go to extreem, think nascar engine idles, it will idle like crap, if at all, at stock idle speeds.
Old Jan 31, 2012 | 02:58 PM
13bpower's Avatar
s4 for life
It is just a sliding scale of increase in high end power power and decrease in mpg, low end power, idle smoothness. It is a trade off that has to be considered with how the car will be used.
Real world I am seeing 16 mpg highway on my large street port. If I was stock port I would be seeing 25+ highway with all my mods consistent.
Old Jan 31, 2012 | 04:25 PM
vl4bad's Avatar
7-Rex
ok i see, so then a bridgeport would see like way less than 16mpg for sure right?
Old Jan 31, 2012 | 04:37 PM
greyseason's Avatar
Zoom-Zoom
It defintily would
Old Feb 1, 2012 | 03:21 PM
13bpower's Avatar
s4 for life
Mixed use I see 14 or so. Bridge could easily put you below 10 mpg depending one how you drive. City you could see 5-7 and highway maybe 12? Considering what a bridge port does that may be worth it. Crazy power in the upper RPM range for what it is. Be prepared for a 1500 rpm idle as well.
_Tones_
May 25, 2021 05:37 AM
1987 T2
11
Apr 1, 2017 11:59 PM
