Dashboard lights went out!
Old Jan 26, 2012 | 06:48 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
I started my car up today after about a week and all of a sudden while I was backing it up, I smelled something burning and noticed a little smoke coming from the back of my car and the lights in my dashboard went out but all the warning light still work and i checked all the fuses and nothing is blown. what could be the problem?
Old Jan 26, 2012 | 06:57 PM
satch's Avatar
Do your tail lights still work?
Old Jan 26, 2012 | 06:58 PM
Wms10th's Avatar
10th Mazda - 10th A.E.
That is the tail light circuit, your tail lights are out also. That's why when the smoke came from the back of the car it killed them. Your tail light fuse is out for sure.
Old Jan 26, 2012 | 08:44 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
The tail lights work fine i pressed the brake and the brake lights went on.
Old Jan 26, 2012 | 08:58 PM
satch's Avatar
The tail lights are not the brake lights. The reverse lights and brake lights are one in the same but neither are the tail lights.
Old Jan 26, 2012 | 10:17 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
so if that is the problem, how would i fix it?
Old Jan 26, 2012 | 10:23 PM
satch's Avatar
Well, first find out if the tails work or not and go from there. Chances are they don't but it would be nice to know either way. And are you sure the Illumination fuse is still good?
Old Jan 26, 2012 | 10:25 PM
Derekcat's Avatar
Rotary Zealot!
Check your headlight switch.. If it has a burnt pin it AND the switch harness are bad. [If so, BOTH must be replaced, and you should do the relay mod from Icemark] Also check your front turn signal sockets for corrosion [clean and apply dielectric grease].
Old Jan 26, 2012 | 11:10 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
Yes I checked the fuse again and its fine.
Old Jan 27, 2012 | 09:52 AM
clokker's Avatar
Cake or Death?
The problem is in the tailight housing, most likely a corroded bulb/socket.
That's where the burning was so it's the logical first place to look.
Old Jan 28, 2012 | 03:02 AM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
Alright I'll check it later on when the suns out and I'll let you know what's going on.
Old Feb 2, 2012 | 06:27 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
I dont see anything wrong with the bulbs or sockets in the tail light housings except for the reverse lights have a white film on the metal part of the bulb.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
