Aluminum Driveshaft???
Old Jan 26, 2012 | 03:50 PM
Shadowscreed's Avatar
Is this an aluminum or steel driveshaft. It came of an 88 Vert and weighs about 10 or 11lbs.
Old Jan 26, 2012 | 04:45 PM
misterstyx69's Avatar
Retired Moderator, RIP
its stock,that Is what I can tell ya.Probably thin walled steel.
link to Mazdatrix: http://www.mazdatrix.com/g9.htm
show the aluminum shaft is 10.65lbs.
Old Jan 26, 2012 | 05:11 PM
Turbo3's Avatar
what is the cup on the yoke for?
Old Jan 26, 2012 | 05:43 PM
It goes over the tail stock and prevents dust and debris from going near the tail shaft seal on the trans.All stock shafts have this.
Old Jan 26, 2012 | 06:34 PM
RotaryEvolution's Avatar
Sharp Claws
rust=steel.
Old Jan 27, 2012 | 05:12 AM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by Karack
rust=steel.
Old Jan 27, 2012 | 07:03 PM
Thanks guys
Old Feb 1, 2012 | 02:40 PM
rx7dd97's Avatar
Convertible Guy
If a magnet sticks to it (look on your refrigerator), then it's steel.
Old Feb 2, 2012 | 04:39 AM
dwb87's Avatar
This is my social media.
Originally Posted by Adam O'Brien
alumminum!!!
Please, do not post false information... Especially since you probably didn't even read most of the thread. It has already been determined that the pictured driveshaft is steel.
Old Feb 2, 2012 | 09:45 AM
Sharp Claws
and mazda never produced an aluminum driveshaft, if you happened across one of the aftermarket ones the easy telltale is: the shaft itself is generally about double the diameter of steel stock shafts to make up for the weaker materials, a magnet sticks to steel and not aluminum and the aluminum shaft is several pounds lighter. just about everything on an aluminum driveshaft looks much sturdier because it has to be, if that pictured shaft was aluminum it would eventually egg out the u-joint holes.
Old Feb 2, 2012 | 09:50 AM
August Burns Red's Avatar
Its rusting so yea steel
LongDuck
Oct 7, 2015 08:12 PM
