Renesis 13B-MSP into FB Swap VIDEO
Old Jan 26, 2012 | 11:02 AM
Directfreak's Avatar
I am a Jeeper Now.
I was lurking around youtube, and found these.
http://www.youtube.com/watch?v=-I1fp...2&feature=plcp
http://www.youtube.com/watch?v=tIKok...1&feature=plcp
Interesting to see.
Old Jan 26, 2012 | 11:22 AM
DarkDrakeX's Avatar
RX-7 NUT
damn thats pretty cool. I bet the swap was a pain in the ***.. Might be a dumb question but why does he have a rx8 cluster??
Old Jan 26, 2012 | 11:35 AM
I am a Jeeper Now.
I think it's needed for the ECU to run.
Old Jan 26, 2012 | 01:40 PM
MannyRX's Avatar
The guy is doing a V8 swap on his 8 so he did a direct swap of the renesis into the 7,otherwise it would be a pita. I would love to take the reni off my 8 to swap it in my first gen...anybody want a rx8 shell with a payment???
Old Jan 26, 2012 | 01:44 PM
DarkDrakeX's Avatar
RX-7 NUT
just get a rx8 salvage with a rear end collision. Probably the best way to do it honestly.
Old Jan 26, 2012 | 06:24 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
correct sir, newer Mazda engines require the factory guage cluster in order to run off the factory management. I've seen it before when a company made a mazdaspeed5 by swapping the DISI turbo drivetrain from a mazdaspeed 3, and found out after much of the hard work was done that the engine wouldn't even fire until the 3's gauge cluster was plugged back in
Old Jan 26, 2012 | 07:07 PM
OneRotor's Avatar
RAWR
That was Car and Driver's Mazdaspeed5 Bosswagon. I drove it while I was an intern. Needs a tune...Bad. Goes into limp mode and dumps mass amounts of fuel when you start to get into boost. It has the potential to be a rocket.
Old Jan 26, 2012 | 08:05 PM
steve84GS TII's Avatar
FB+FC=F-ME
Thats the problem with OBDII,everything has to be there......engine ECU,trans ECU,instrument cluster,and often the ABS,TCS and other computors.His check engine light might never go off without a complete swap, and it definately wouldnt be CA legal.
Cool,but a PITA.
Old Jan 26, 2012 | 09:33 PM
nofords's Avatar
Mr. September FB 2011
***Sidetrack***
It's not an OBD II thing...its a CAN Serial Bus thing.
Lots of both platforms can and have been turned into stand alone. CAN Serial bus computers are harder to do but not impossible. Just give the ECU what it needs.
Its similar to my ls swap and others who are running GTO LS2 wiring which requires the fuel pump, BCM, PCM, TM, TAC Pedal, cluster etc all to talk to each other (CAN Serial Bus). If you eliminate one of said items, you need to replace it with values the PCM needs to operate.
I do not have an SES light but more an ABS light, which i can fix with a little black box...
anyways, back on topic! Cool Swap!
Old Jan 27, 2012 | 01:08 AM
Bern's Avatar
Thanks for sharing mighty cool!!
-Bern
Old Jan 27, 2012 | 09:22 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Smokes worse than my car did before I tore it down to find the oil rings totally shot.
And I won't comment on the kind of thinking that leads to lighting the tires up while nose-in to the garage, except to say "coming soon, to the inside of a 7-11 near you..."
Old Jan 27, 2012 | 11:37 AM
RE-ALL DAY's Avatar
^^ yea not the greatest idea to do while burning out
Old Mar 28, 2013 | 04:32 PM
Qingdao's Avatar
HeyHeyHey..Its the Goose
I got this idea while I was at work today... had to do a search to see if it has already been done. Apparently it has.
I dig the idea, but does the Renesis share the same intake ports as a 6 or 4 port 13B? So could a crafty man stick a carb on it?
EDIT: ^^^ No it doesn't :P
EDIT 2: Well... the bolt holes look similar. I want to get a cheap rx8 gasket now.
Old Mar 28, 2013 | 05:32 PM
Qingdao's Avatar
RX8: Intake - Kits/Air Filters: RX-8 Engine Carburetor/Manifold Adapter Plate -
EEEEEKKK!!!
My issue with spending all of my money I don't have just got WORSE
And I also, found out that the regular water pump cannot be used???
Old Mar 28, 2013 | 06:11 PM
j9fd3s's Avatar
Community Builder
why not? the Rx8 water pump is like any other pump
Old Mar 28, 2013 | 06:54 PM
Qingdao's Avatar
04 08 Mazda RX8 RX 8 renesis 13B 6 Port 6 Speed Motor Engine 36K | eBay
Cause this dude said so... Figured he might know something I was unaware of like bolt position or oriface size. I've messaged him. He said it spun backwards???; I don't see how thats possible. But there could be another reason.
I'd perfer a water pump that a clutch fan could spin off of.
Old Mar 28, 2013 | 10:12 PM
verrt's Avatar
The Star Mazda race cars use Renesis engines. I seriously doubt they had a RX-8 cluster.
Old Mar 28, 2013 | 10:23 PM
Jeff20B's Avatar
Lapping = Fapping
The FD warterpump spins backwards compared to ours and FCs. Can't recall which way the RX-8 spins, but j9fd3s ought to know.
Old Mar 28, 2013 | 10:28 PM
ive been seriously tossing around the idea of picking up a low-ish mileage 6 port renesis to swap into my FB. I have most of the needed bits/fab skills to make it work, and the renesis OE build easily rivals most older "race" builds even in terms of basic parts, clearances and balancing
Old Mar 29, 2013 | 12:25 AM
j9fd3s's Avatar
Community Builder
they run motecs.. the trick with an aftermarket ECU is all the valves in the intake...
the Rx8 water pump is in the front cover, but that one has been cut in half, and is using stock RX8 bits, and i see no reason it wouldn't work...
buy a core, and then a Mazda reman, those are $2001 new, with a $1000 core, so
Old Mar 29, 2013 | 12:56 AM
Qingdao's Avatar
I guess the water jacket is the same (or close enough) on the older 13B's where any pump will pump the same as long as it bolts up and the belts are in line.
$2001?! Thats not bad at all. That's for just the keg?
Think they would accept a bunch of old housings, a rotor, one end housing, and a beat up mid plate as a core?
What about mating to the first gen transmission? I guess I could use the auto counterbalencer and a lite weight flywheel. Cause I'm sure the 8's clutch wouldn't fit in the bell housing of the first gen.
I might look into this...
Old Mar 29, 2013 | 10:38 AM
j9fd3s's Avatar
Community Builder
that one on ebay is running stock Rx8 water pump/alt and belts.....
the bolt pattern to the trans is the same, but the Rx8 uses a turbo sized clutch. AT cw and FB flywheel, and it should go right in
cleann88
Jan 15, 2022 11:28 AM
Under PSI
19
Sep 23, 2015 11:47 PM
The1Sun
Sep 15, 2015 04:45 PM
