Transmission
Old Jan 22, 2012 | 12:30 AM
1bad20b's Avatar
Transmission
Need some advice on what transmission to use. My 20b is tuned to 715whp and 610 ft lb and i need a transmission that can be shifted without clutching. I have had the car up much further up past 800 hp but i am not planning on doing this again. Hoping that someone finds a t56 dog gear conversion kit or something similar. The car has a t56 on it now. Very phew tranmission can handle the power and im trying to stay under 9000 dollars. Thanks.
Old Jan 22, 2012 | 07:57 AM
turbodrx7's Avatar
PURIST
Ive heard t56s have trouble shifting at real high rpm. What does the 20b rev to? Why not just build the t56 if the redline isnt the issue?
-Austin
Old Jan 23, 2012 | 09:37 AM
Bacon's Avatar
IRS 4 Life
your gonna be looking at a Gforce, g101 or gf5r or a liberty trans, http://gforcetransmissions.com http://www.libertysgears.com/
best is to head to the drag racing section, you may find more leads there
Old Jan 23, 2012 | 07:46 PM
SPEED_NYC's Avatar
RX-Parts
Bacon is right, but be aware that all of the clutchless shift trans options are not very streetable. I know you're car very well, and that car is too clean to make a drag race only car... many of the clutchless shift trannys from g force and liberty do not allow downshifting either.
your car uses the same Adapter plate and bellhousing that I use on my T56 conversion. My T56 is built by G force, but is not a clutchless, it has upgraded gears, shafts, and modified syncros. the trans shifts at 9300RPM with me, but does have some trouble powershifting above 8500. it's probably your best option for strength and still keeping the car streetable.
http://gforcetransmissions.com/tran_gt-56.asp
so.. when you bought the car from Carlo, he sold you the screen name too?
Old Jan 23, 2012 | 08:59 PM
Rob XX 7's Avatar
FC guy
you mean not streetable- period. Not "very streetable"
Cannot be driven on the street at all
Im going to throw a Rockland Tranzilla/ Magnum into the mix, but whatever you do decide pay close attention to the gear ratios as it seems alot of them are really not set up that great.
Old Jan 24, 2012 | 03:30 PM
1bad20b's Avatar
thanks for all the adivice everybody , the car is now going to be used for drift and time attack hopefully. I think im going to go with this =http://www.ppgearbox.com.au/page.asp?productid=32
Old Jan 24, 2012 | 03:33 PM
1bad20b's Avatar
no he didnt but i carlo is a very reasonable guy and if he knew that by me putting this an my username i would get more people who knew the car he wouldnt mind, and thanks for the info.
Old Feb 9, 2013 | 06:00 PM
bewtew's Avatar
1BAD20B
Welcome to the forum! glad to see you on here.
before i did the T-56 conversation i did a lot of research and the main problem is that the Sequential gear box that are available are rate to 600-700 tq and are over 10k+ for the transmission alone. that means you will be blowing 10k transmissions with the 20B at high boost levels.
ppg makes a dogbox kit http://www.ppgearbox.com.au/page.asp?categoryid=8
if you plan on using the car as a full blown race car than go for it but you going to hate it as a street car... trust me.
the T-56 that is on there is fully built with a Tick performance kit. it will handle 1000 tq no problem and i have power shifted at 8500rpm with no problem as well.
i did a lot of tracking with the car with that setup and the car was pretty much untouchable on track. you can change the gear ratios in the transmission if u want a closer gear ratio.
just enjoy the car.. pm if u have any other questions
Old Feb 9, 2013 | 06:03 PM
bewtew's Avatar
1BAD20B
no i dont mind at at...
did u ever take the car to defined autoworks to get the v-mount done?
did u re-tune the car and made more power?
Old Feb 9, 2013 | 09:52 PM
Bacon's Avatar
IRS 4 Life
Ppg gonna blow apart, ask turbo tommy ... Factory case flexes an 6k goes down the toilet
Old Feb 9, 2013 | 10:49 PM
bewtew's Avatar
1BAD20B
i thought he was still running that transmission...
ppg makes dog gears for the T-56 i doubt the case will flex on a t-56.
Old Feb 10, 2013 | 06:45 AM
indispeed's Avatar
try there guy's ... Saenz Performance.. they make Sequential gear box
for around 10k
Old Feb 10, 2013 | 03:14 PM
1bad20b's Avatar
I'm still running the t56 as is no changes. I realized why change what working very well. Good advice though thanks all.
Old Feb 10, 2013 | 08:33 PM
Bacon's Avatar
IRS 4 Life
Nope blew it up, fixed and replaced the case, then snapped the main shaft and they didn't make the replacment any more or something like that... And he has should his fd since then...
T56 is solution for anything street driven
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
