Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
4g63 fd
Old Jan 21, 2012 | 02:38 PM
Bean4G63's Avatar
4g63 fd
I picked up a 1993 Red R1 back in June without a motor. I have been slowly been making progress over the last few months and am in the process of getting it ready for a complete color change to Carbon Grey Metallic. I will be running a built 4G63 with a PTE6262 and should easily make 550-600whp on straight pump gas. I will be using an AEM v2 box for an ECU. The traction control and boost by gear should help put the power to the ground. I am keeping the RX7 trans + rear end. I will also have power steering and A/C. I am building it to be a fun street car. Here are some pics of the progress so far:
Mock up motor installed:
Turbo manifold:
6 bolt DSM flywheel machined for Exedy Triple Disc:
Custom FMIC:
Motor Mounts:
Car primed and ready for paint:
Old Jan 21, 2012 | 02:48 PM
wizzurp's Avatar
rotard
D50/mighty max tranny or a bell housing adapter? Looks like it'll be fun
Old Jan 21, 2012 | 03:05 PM
flyboy333's Avatar
Just a hint of crazy.
Wow, seems very thorough and way interesting! Definitely want to see how this unfolds
Old Jan 21, 2012 | 03:25 PM
Bean4G63's Avatar
Im running a B2600 bellhousing. I originally was going to put a wideblock 4g63 in it but since they are hard to find and I had three or four narrowblocks lying around I decided to go with the narrowblock and an adapterplate. I also didn't like the way the wideblock sat at an angle when bolted to the bellhousing so I stood it straight up with the adapter plate.
Old Jan 21, 2012 | 03:34 PM
Bean4G63's Avatar
Valve cover, intake manifold, and other small items are at the powder coater now. I just picked up some missing interior plastics from Fritz yesterday so there are only a few small items left and the interior will be complete. Once the car is painted I will be going they the stock main harness, cleaning it up, and re-looming it the best I can.
Old Jan 21, 2012 | 04:10 PM
just startn's Avatar
Turbo vert
Nice!!!. Pics of the shifter hole please? I am very very very interested in the turbo manifold setup. It looks like it sucks the turbo close enough to the block to fit in a Colt. Any dimesions, solidoworks ect. of the mani?
Old Jan 21, 2012 | 04:52 PM
Bean4G63's Avatar
Im using the stock trans, driveshaft, and rear so the shifter is still in the stock location. The manifold is made from 1.5" schedule 10 stainless. I don't have any drawings as I don't draw any of them before hand. I have an idea in my head that I just go with and tweak it till I'm happy with how it looks.
Old Jan 21, 2012 | 05:09 PM
Len-Len's Avatar
Lenny
You ******! I was debating on doing this swap to my shell but decided to stay rotary. Seeing you do it to your car makes me wanna change my mind again. Very nice!
Old Jan 21, 2012 | 05:25 PM
Turbo vert
IC. were do you order your yubing from?
Old Jan 21, 2012 | 05:36 PM
Bean4G63's Avatar
Thanks. I've been talking about doing it for a long time. Just never could pull the trigger on it. Haha!
Old Jan 21, 2012 | 07:51 PM
Bean4G63's Avatar
I buy the schedule 10 stainless from Mcmaster carr and the aluminum bends are Vibrant.
Old Jan 21, 2012 | 10:41 PM
dbragg's Avatar
Say hello to Mr.Wankel
I love this swap. Debated doing it a few times, probably will do it in some rx7 at some point. Keep up the good work.
Old Jan 21, 2012 | 11:31 PM
Turbo vert
Im trying to do it in a fb.
Old Jan 22, 2012 | 09:50 AM
dbragg's Avatar
From my research, it shouldn't be that hard of a swap to accomplish, all things considered.
Not trying to thread jack, but here is a great source of info for anyone looking to get into this:
http://www.projectzerog.com/
Old Jan 22, 2012 | 10:27 AM
Bean4G63's Avatar
Projectzerog.com has some real good info. That website is how I found out about the B2600 truck bellhousing. Motor swaps are not hard, they just take alot of time and custom fab work. I have done quite a few of them and finally decided to do one for myself. I figured that if I could fit a 2jz in a 300zx then fitting the 4g63 in an FD should be much easier.
Old Jan 23, 2012 | 09:00 AM
CKxx's Avatar
This is being built over at TurboTrix, correct? I'll have to check it out sometime. I'm doing a 2J car about an hour away near Philly.
Old Jan 23, 2012 | 06:28 PM
Bean4G63's Avatar
Correct. Swing by if your in the area.
Old Jan 24, 2012 | 08:45 PM
Bean4G63's Avatar
Modified my fuel pump sender and installed a Walbro 400 pump today. I welded a -8an fitting to the end of the feed line and ran 10 gauge power and ground directly to the pump.
Old Jan 24, 2012 | 09:55 PM
Narfle's Avatar
Rx7 Wagon
What are you going to do for a sub-frame?
Old Jan 25, 2012 | 08:19 AM
Bean4G63's Avatar
Subframe is done. I modified the stock one.
Old Jan 29, 2012 | 09:07 PM
SOB Racing's Avatar
I've been looking at doing this as well, can't find a B2600 bellhousing very easily.
Old Jan 30, 2012 | 06:45 PM
Bean4G63's Avatar
Go on car-part.com and search that site. They had a few of them when I got mine.
Old Jan 30, 2012 | 09:23 PM
SOB Racing's Avatar
Cool Thanks!
Old Jan 30, 2012 | 09:38 PM
BADSVN2000's Avatar
this is def very original, good on you for doing the conversion. Im a rotary fanatic but i fully appreciate what you are doing, hell ive help put rotaries in so many different types of vehicles what you are doing is no different! keep it up
Old Feb 1, 2012 | 10:09 PM
Bean4G63's Avatar
Got half the car painted today. We will hopefully be finishing the last half tomorrow. Then I can put it back together and start on the wiring.
