Series 5 Diff.
Old Jan 20, 2012 | 03:34 PM
fastlemons's Avatar
Question Series 5 Diff.
Hi,
I've recently purchased a Series 4 Turbo RX7, but it has a terribly diff whine, and the cost of rebuilding is rather high, However i have been offered a series 5 Viscous LSD but i'm unsure if it will fit straight in.
Any help will be great.
Old Jan 22, 2012 | 07:03 AM
Landon303's Avatar
LSD to LSD turbo diffs should be direct fits
Old Jan 23, 2012 | 02:50 PM
fastlemons's Avatar
Thanks for the help. I have purchased the diff and will fit it when the weekend arrives. Which oil should use for the diff?
Old Jan 23, 2012 | 03:56 PM
JerryLH3's Avatar
Rabbit hole specialist
The diff itself will fit in the case, but I believe you will need stub shafts to match whatever differential you are using. They are not all the same.
http://www.mazdatrix.com/G8DiffMnt.HTM
Old Jan 23, 2012 | 08:13 PM
Phoenix Jones's Avatar
Clutch Type > Viscous
Old Jan 23, 2012 | 09:23 PM
Evil Aviator's Avatar
Rotorhead
The fully-assembled units will swap out with no problem.
The type and amount of fluids are listed in the factory service manual, which is available free at this website:
http://foxed.ca/index.php?page=rx7manual
