T3 Turbo manifolds
Old Jan 14, 2012 | 05:41 PM
Eva001Ikari's Avatar
Working on my car.
T3 Turbo manifolds
I've been looking into the "going single" scene just recently and I've found a lot of good information. This is not a "which turbo should I get and for what reasons..." thread so recommending different turbo applications and such isnt what i'm looking for.
I've decided to go with the Turbonetics GT-K 450 or 500 series turbo. The problem is that the exhaust inlet flange is a T3 style. I've been through a whole crap load of sites (including this one) and apparently there isnt very much support for the t3 manifold....as a matter of fact, I haven't found a single one. Turbonetics does make 3 gtk series turbos with the t4 flange style however they are the 650, 850 and 1000 trims, and I do not need something that big or expensive for my application.
So my question is: Are there any t3 turbo manifolds out there that I can buy, without buying a whole turbo kit? If there is not: Where would I go to get a custom set up made, and is it worth the trouble?
Thanks guys.
Old Jan 14, 2012 | 08:29 PM
XLR8's Avatar
A-spec will build any manifold you need. They are quality. I have one of their older T3 manifolds and it has been great. Power level in sig with build thread. Shooting for 500whp this year with AI. Should be no problem
www.a-spectuning.com
Old Jan 14, 2012 | 08:40 PM
Turblown's Avatar
Turn up the boost
Rotary Performance Parts
Old Jan 15, 2012 | 09:23 AM
Working on my car.
Excellent information. Will definately be looking into Aspec and turblown when I get ready to start this whole project. Thanks.
Old Jan 22, 2012 | 02:10 AM
RexRyder's Avatar
What are your power goals? I think the gtk 450 and 500 can only do like 350??
Old Jan 22, 2012 | 08:46 PM
Working on my car.
I'm kind of lost on how much power each turbo can produce but I was told once that whatever series it is, is how much power it makes, ie. 450 makes 450 give or take and 500 makes 500 etc, etc.
Old Jan 23, 2012 | 09:52 AM
Zero R's Avatar
Just in time to die
Those turbo's are good if you're wanting to be in the 300whp range.
~S~
Old Jan 23, 2012 | 10:22 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
"450 makes 450 give or take and 500 makes 500 etc, etc."
you probably need to listen to the rotary guys on the board before you do something you will regret.
Turbonetics, and most other turbo vendors, are talking PISTON HP...
piston hp gets divided by 1.3 to get to ROTARY HP.
so, 450 / 1.3 = 346
just trying to be of help.
howard
Old Jan 23, 2012 | 12:02 PM
RexRyder's Avatar
Damn I was close! Good thing I mentioned something.
Old Jan 26, 2012 | 09:38 AM
Working on my car.
it is a good thing you mentioned something. ok i'll look into that then. Maybe I'll start looking at the 850 and then not have to worry about finding someone to make a t3 manifold. Thanks for the info Howard.
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
