RX-2 using high pressure EFI fuel pump
Old Jan 12, 2012 | 11:27 AM
R.P.M.'s Avatar
Likes to swear....alot
Any of you guys running EFI engines in your RX-2's, I'm wondering what you did (if anything) to plumb in a high pressure fuel pump?
I have never opened up the stock tank to see if its baffled inside, but I doubt it is.
If I fitted an inline fuel pump to the stock pickup tube, how bad am I going to loose fuel pressure around 1/4 tank?
I guess the most sensible thing to do is build a swirlpot system ehh?
Old Jan 12, 2012 | 02:17 PM
surem03's Avatar
ROTARY KING
Don't know abort the fuel pump but the stock tanks are baffle. I open one up to do repair.
Old Jan 12, 2012 | 02:45 PM
turbo_dave's Avatar
#turbodavebuilt
Anything below 1/4 tank is no good for the Efi pumps cause it picks up air while fuel is moving around.I have Efi now and gotta keep above 1/4 tank or else it starves for fuel while I'm boosting.best thing to do is make a surge tank and that will solve all the issue.
Old Jan 12, 2012 | 02:50 PM
R.P.M.'s Avatar
Great! thanks for the info.
Mine is not going to be boosted, so for now I think I'm going to plumb a walbro inline and keep it above 1/4 tank.
Old Jan 12, 2012 | 05:38 PM
bumpstart's Avatar
talking head
in oz in older times we used to mount a surge tank in the boot , and feed it with a lift pump from the original location
that steals a bit of boot space and can make for some smells
i drove around like that for many years
currently i have taken the pump and bracket assembly from a s4 rx7,, shortened the drop and welded the flange onto the top of the capella tank
this gives a submersible pump ,, but lacks the boxed baffle as is normally seen around a submersible efi install
it hasnt run in this config yet so yet to see how that copes during cornering
/ am contemplating opening it back up to add in a rudimentry box
Old Jan 12, 2012 | 09:45 PM
Siraniko's Avatar
RX for fun
Gas tank's drain is also an option as a supply line to the fuel pump.
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
