Mounting gauges in the Glove box?
Old Jan 12, 2012 | 07:19 AM
NVMYRX-7's Avatar
If it's fast I'm There
I am trying to find out if anyone sells or can fabricate a mount for two-three gauges to fit professionally in the glove box of a 1994 RX-7. Yes, I'm talking show car quality!
Yes I’ve searched but most threads end up going with the airbag or center speaker mount solution.
I only have one visible gauge (boost) mounted on the steering wheel pod, so please no comments about mounting them anywhere besides in the glove box out of sight.
Old Jan 12, 2012 | 08:01 AM
DaleClark's Avatar
RX-7 Bad Ass
I don't think there are any shop-made gauge panels for the glove box. Probably wouldn't be too hard to fabricate with a sheet of plastic or carbon fiber.
Also, mounting them all the way over there is pretty useless, you won't be able to read them. The only gauges you really need on a street car are boost, water temp, and maybe a wideband. May also want to think about some sort of slim digital gauge to put in the radio pocket - you can close the door in the pocket to hide them but they're much closer to line of sight.
Dale
Old Jan 12, 2012 | 08:21 AM
NVMYRX-7's Avatar
Dale
Thanks Dale,
I want to mount a wideband and water temp in the glove box because I don't need to look at them every five minutes. I have zero fabrication skills which is why I'm asking if anyone has the ability to fab one up or has already done it.
Old Jan 12, 2012 | 11:38 AM
F1GURIN's Avatar
#255/1000
double post.
Old Jan 12, 2012 | 11:40 AM
F1GURIN's Avatar
#255/1000
Wanna blow your mind on this one? It blew mine.. When i buy my fd im doing this and running boost and wideband. But shh, keep this on the DL, its not done alot
http://www.rotaryaddicts.com/?page_id=763
Old Jan 12, 2012 | 12:39 PM
NVMYRX-7's Avatar
I repeat please only post glove box ideas.
Thank you
Old Jan 12, 2012 | 01:01 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
I know you're joking because people have been doing that for years IMO it is not seen much because it does require some skills. At least that is why I have never attempted doing that. As I don't really feel like experimenting on my panels if you know what I mean. Of all the people that I have seen do similar mods my favorite one was this one guy that took apart his power FC commander and seperated the screen from the buttons. In the climate controls panel he had the screen, next to the shifter he placed the buttons. And IIRC he also relocted his climate controls. The end result was quite nice.
Thank you
Honestly dude I don't know of anyone that manufactures something like that for a glovebox. It is my understanding that it is all custom made. You could just go to a soundsystem place that does custom subwoofers they should wip you up something really nice.
Old Jan 12, 2012 | 05:44 PM
NVMYRX-7's Avatar
This is what I want!!!
If the WRX has them, I know our powerful minds have a source
http://www.fastwrx.com/aumeglboxgah.html
60mm gauges w/the control unit:
52mm gauges:
52mm gauges close-up:
Old Jan 12, 2012 | 05:47 PM
mrb63083's Avatar
HKS used to make a pod, at least they did for the FC. I had one on my old FC. Maybe try searching the net.
Old Jan 12, 2012 | 10:28 PM
F1GURIN's Avatar
#255/1000
Damn you got me Yeah i do believe seeing that one. Its not hard to make anything, just depends on how much time you put into it, you can do this glovebox gauge thing easily, it looks just like a box that fits into the contours of the glovebox and however many holes for the gauges, then arc them alittle bit. simple and would almost never be looked at during driving.
