2 Wire Plugs. What do they do.
Old Jul 21, 2002 | 03:38 PM
silverrotor's Avatar
2 Wire Plugs. What do they do?
In a Series IV N/A, their are 2 6 hole white wire plugs. For each of them they have 4 wires feed to them.
One Is located at the Boost sensor, towards the passenger side.
The other, Is located on the side of the Driver shock tower, behind the Main Fuse Box.
I have been meaning to ask this for awhile know.
Old Jul 21, 2002 | 04:01 PM
Suds's Avatar
Boost sensor? N/A?
Old Jul 21, 2002 | 07:01 PM
mine has them now because I took off my AAS auto adjustable suspention
Old Jul 21, 2002 | 07:27 PM
dre_2ooo's Avatar
Originally posted by Suds
Boost sensor? N/A?
AKA atospheric pressure sensor .
Mine are connected to my AAS (Auto-Adjusting Suspension).
Old Jul 21, 2002 | 07:52 PM
Sniper_X's Avatar
those are for the Automatic Adjusting suspension
Old Jul 21, 2002 | 08:04 PM
NZConvertible's Avatar
I'm a boost creep...
Originally posted by dre_2ooo
AKA atospheric pressure sensor.
Actually, the atospheric pressure sensor is inside the car, behind the passengers kick panel. The manifold pressure sensor is on the RHS shock tower of both NA and Turbo.
Old Jul 22, 2002 | 06:32 AM
So they are for the Automatic Adjustable Suspension? They are In front of both shock towers.
My FC Is a GXL. If It Is a GXL, perhaps the previous owner took out the actuators off the top off the shocks.
Can anyone confirm, for sure, If these plugs are Infact related to the A.A.S?
Old Jul 22, 2002 | 06:51 AM
HAILERS's Avatar
HAILERS
The plugs are most likely there hidden away on all models. Its easier to make a single harness for all cars rather than making five or six different harness. You'll find extra plugs all over the car that are unused. Such as for electric mirrors if you don't have those. The plug is just stuffed away. Same with cruise control.
Old Jul 22, 2002 | 07:25 AM
I'm Inclined to believe that they are for the A.A.S.
Thats great b'c I can use them for the RPM Switch, Instead of the battery (non Ignition switched) and the other one can be used, Instead of my Diagnostic plug (Ignition swiched, again) that I am currently using for my electric fan (I have always felt uncomfortable about this one). I'm sure NZCovertible will be exstatic about this one!
Thanks guys
Old Jul 22, 2002 | 04:57 PM
I'm not sure why you think they're any different, but whatever works for ya man.
Old Jul 22, 2002 | 05:01 PM
HA HA HA
wretchedegg
Nov 19, 2025 03:07 AM
toplessFC3Sman
Mar 20, 2018 01:54 PM
ryanschneider2006
Nov 14, 2015 01:34 PM
