Strange problem with engine fans
Old Jan 8, 2012 | 07:53 AM
imitek's Avatar
imitek
Right ive not looked into it yet mabe some 1 here has had this problem
What happens is ignittion on engine off fans turn on wiggle the loomb atached to ecu fans turn off
It sounds like wireing problem( loose or broken) but as i said ive not looked into this problem yet been doin engine work
Also temp and oil presure gauge playup randomly
Any advice will be helpfull thanks
Old Jan 8, 2012 | 09:25 AM
Mrmatt3465's Avatar
Lousy Crew Chief
Top Answer: 1
Make sure you're ecu is actually bolted down. There are grounds that ground to the frame that holds the ecu and then ground to the car when it's bolted down
Old Jan 8, 2012 | 10:44 AM
imitek's Avatar
imitek
Ill give it a go diddent even think of that lol the ecu is on the floor
Thanks
Old Jan 8, 2012 | 11:24 AM
Mrmatt3465's Avatar
Lousy Crew Chief
Top Answer: 1
guarantee that's why
Old Jan 8, 2012 | 12:39 PM
imitek's Avatar
imitek
Yea does make scence im gona check it soon as i get time
An ill get back to ya
streetlegal?
Mar 17, 2022 02:46 PM
Rotospectre
Mar 28, 2018 03:33 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
7aull
1st Gen General Discussion
Aug 14, 2015 10:44 PM
