Manifold needed for HX52?
Old Dec 29, 2011 | 12:02 AM
jaggermouth's Avatar
Will TIG for 20b
Was going to attempt to make my manifold but need to have the car done ASAP and do not have proper tools to do a great job.
I have seen other use an HKS cast manifold on their FCs but I have an REW in my FC.
Could anyone confirm that a cast manifold will work on my setup to save myself some time?
Old Jan 2, 2012 | 11:14 PM
Will TIG for 20b
Any help? Not even "SEARCH"? Only found a few regarding HX52 in a FC..
Old Jan 2, 2012 | 11:35 PM
rxspeed7's Avatar
F-IT
it will work, Both engines are the same mounting wise. iirc there's more clearence on the fd lower intake manifold than the fc's. do you have a cast fc manifold?
Old Jan 3, 2012 | 11:59 AM
Will TIG for 20b
None yet, but was looking at either or.
Old Jan 3, 2012 | 05:22 PM
RX7(613)'s Avatar
If you use the FC cast manifold, you have alot of clearence as it pushes the turbo forward.
If you use the Cast FD manifold, you might have to run a spacer if your hotside is big.
Old Jan 3, 2012 | 07:02 PM
rxspeed7's Avatar
F-IT
from what i've read(no real personal exp) the fd design has a poor wg runner design. I have ran a hks fc cast manifold for the last 4yrs with no problems. my setup was a precision 6776 with a 40mm hks wastegate. made 400whp on a mustang dyno. never once had a boost control issue either.
Old Jan 3, 2012 | 07:27 PM
Will TIG for 20b
maybe I'll source an FC one.
I gave making a manifold another attempt today. I got it so the
turbo will fit, but I'm having a bitch of a time with adapting pipe to the T4 inlet holes.
Any thoughts on that? I'll probably just get an HKS one, but thought Id keep trying in the mean time.
Old Jan 3, 2012 | 08:03 PM
12AllWays's Avatar
It means 12A all ways^
Is the Holset HX52 even t4? I was thinking they were bigger. I have a HX40 on mine right now and it is t4.
Old Jan 3, 2012 | 08:12 PM
Will TIG for 20b
The mounting holes are slightly off
Old Jan 3, 2012 | 09:03 PM
12AllWays's Avatar
Thats what I was thinking. But the 52 is one big turbo, I wouldnt go with a cast manifold just due to the fact that it wouldnt be fully divided.
Old Jan 4, 2012 | 11:58 PM
misterstyx69's Avatar
Retired Moderator, RIP
"international flange"?..(read something about a flange called that being slightly bigger than T4)
Old Jan 5, 2012 | 12:11 AM
Will TIG for 20b
Called a "Holset H2" flange I think. Nothing a drill or an air tool can't fix.
On a side note, I tacked up my manifold today. Fitment is not bad considering it was my first one. It's quite short, probably similar to an HKS. Going to get my friend to help me TIG it on Tuesday and then figure out placement for twin 38mm gates.
Also have the oil feed/return stuff coming soon.
Old Feb 13, 2012 | 04:16 PM
hkp's Avatar
hkp
big turbo spoolin
sup bro, i run the hx52 on a cast hks manifold. youre right, a drill is the answer to your flange issue, the holes are a little off. ive been using this setup for a couple of years. my latest setup is haltech e8, 550 1600, ls1 coils, walbro and aftermarket reg. with stock rails. let me know if you need any thing.
Old Feb 13, 2012 | 07:02 PM
Will TIG for 20b
Using a FC ebay manifold with the WG flange cut off and a tial vband welded on.
Just waiting on a turbo oil flange and gasket and I'll be ready to fire her up again
Old Feb 13, 2012 | 09:24 PM
silverfdturbo6port's Avatar
500+hp club
id go holset vgt turbo they have a 67mm version and a 72mm version. Instant boost and no back pressure best of both worlds
