Sponsored by: CARiD
running lean with rtek1.8
Old Dec 24, 2011 | 04:26 PM
blacken_rotary's Avatar
S5 t2 stock everything except
*rcinjector 720 primary and secondary
*255 walboro
*aem afr
*ecu rtek 1.8
At idle afr Is 10.5-10
And on top end it climbs to afr 13-16 all around
Car shoots no smoke and shows no sign of hesitation
Any idea why I'm goin lean?
Old Dec 24, 2011 | 04:50 PM
flaco's Avatar
o2? tps? afm? whats your fuel pressure on boost?
Old Dec 24, 2011 | 04:57 PM
02 sensor was replace
I have stock fuel pressure regulator
Afm I switch wit a friend of mine n still reacted the same
Tps not sure on dat
Old Dec 24, 2011 | 05:55 PM
bumpstart's Avatar
talking head
fuel filter changeout
also check fuel pump for dead head pressure test or flow rate test , may need replacing,, may need a bypass relay
Old Dec 24, 2011 | 07:23 PM
flaco's Avatar
yep and try get an aftermarket regulator
Old Dec 24, 2011 | 09:31 PM
fuel filterus new
Ima check fuel pump tmrrw............
I have a vortex fmu but don't know wat ratio it is
Old Dec 25, 2011 | 02:36 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
if your leaning out at high rpms with your setup, its most commonly the fuel pump. Either its going dead, or its not getting full voltage at high rpms. Also, be weary of chinese knock off walboro pumps. I had one from previous owner and the flow died out at high rpm.
Old Dec 25, 2011 | 10:32 AM
K-Tune's Avatar
FD Daily
Be sure your AFM is the correct part number. Should be N370, N390, N3A1. anything else won't work.
Queppa
Nov 18, 2024 03:47 AM
Tylerx7fb
39
May 27, 2019 12:45 PM
rotor_veux
46
Jun 12, 2018 10:39 AM
Jun 26, 2016 10:21 AM
smikels
Aug 18, 2015 01:26 PM
