Megasquirt TIP120 component for Fidle
Old Dec 23, 2011 | 01:06 PM
kutukutu1's Avatar
Hey guys i built my MS v3.0 and for my first gen i am gonna use the bosch Fidle valve. My question is were would i mount the component because the Megamanual says to mount it in the heat sink but i dont have any room left in the heat sink. were have your guys mounted it?
Thanks
Old Dec 24, 2011 | 06:57 AM
muythaibxr's Avatar
MegaSquirt Mod
Remove the IGBT from the heatsink and board and put it in that spot.
Ken
Old Dec 24, 2011 | 10:25 AM
Aaron Cake's Avatar
Engine, Not Motor
I just bolt it to the case using an insulator kit.
Old Dec 24, 2011 | 03:07 PM
kutukutu1's Avatar
were exactly do i install the diode that it says i need to install for the flyback of the valve? Also aaron cake i see that you have it soldered to the db37, why exactly did you do that? Do i just do it like the megamanual says to do so? Thanks sorry for all the questions.
Old Dec 25, 2011 | 09:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Nothing is soldered to the DB37, that's just the angle of the camera. The picture was taken before the TIP120 was bolted to the case so it is just floating via the wires.
I generally place the diode up at the relay. See http://www.aaroncake.net/rx-7/megasq...Megasquirt.asp , about 3/4 down the page.
Old Dec 26, 2011 | 04:00 AM
kutukutu1's Avatar
thank you very much appreciate the help
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Heedlessone
Sep 16, 2015 11:31 AM
