Megasquirt My MS / 13b pp project update/slash some questions
Old Dec 22, 2011 | 02:00 AM
Broke Mechanic's Avatar
VA My MS / 13b pp project update/slash some questions
I wanted to thank ken and aaroncake for all their info around the web and i chose to get the MS-3 w 3.57 already built from DIYauto tune. I am sometime away from hooking up the ecu though. I just got the motor in the car and from the advice on the forums, i figured since i already have a 51mm ida carb i would hook that up to break in the engine a little and make sure my rebuild is up to par-then i will hook up the MS since i haven't done anything like this before. I have been playing with the MS and the Tunerstudio and i was wondering what version of MS i should run on the ecu. I understand that MS-3 software is still in developement, but most of the existing features work the same. Any input on software versions and their simplicity or benefit would help. I also got the MS Display, but i'm not sure how much i'm going to like it....it looks a little hard to read. I read you can use racepak with the ms-II, does anyone know if racepak can be used for ms-III? I need it for display only-not data logging. Any other display options anyone is aware of? Anyway, just thought i'd give an update. I'm sure you'll be hearing more from me once i get around to installing the MS, i'm a little worried about getting the Crank Angle Sensors set right, thats the only thing i'm a little confused about. I'm gonna make a dyno run with the carbs next week, so i'll have a pre-ms hp number to compare to. BTW its a 13b PP series 5, i have TWM tbi's to go on it and rc injectors-basically the same setup as i had b4 on my rx with the 51mm IDA's except i used better seals this time so i can run nitrous.
-Kevin
Old Dec 22, 2011 | 09:59 AM
just startn's Avatar
Turbo vert
There are alot more dashes avail. then racepak. Racepaks are nice but alot of $ and if your not using it to its full potential its sorta a waste i think. Look at PCS setups.
Old Dec 30, 2011 | 12:22 AM
nvmarx's Avatar
hey man i have the same engine what throttle bodies and injectors are you going to use?
vipernicus42
Mar 7, 2016 04:57 AM
turbo-minivan
69
Feb 4, 2016 12:29 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
