Custom Wiring harnesses?
Old Dec 17, 2011 | 11:54 AM
slitherz90gxl's Avatar
Resident Rotard
So, while I'm saving for my rebuild, porting irons, bonding hammer dents, etc, etc, etc. I figure I'll probably re-do my whole wiring harness. My factory wiring harness is redneck/hillbilly spliced and cut, and I removed/blocked off all the emissions. As well as chipping the ecu to do away with the pesky s5 MOP limp modes.
Enough about myself, I figured somebody has some pictures of their custom wiring harness so lets see them!?!?!??!?!?!?!?!
Thank you.
Old Dec 17, 2011 | 12:01 PM
Rotank's Avatar
Slung all my rods
I don't have an FC harness, but here is my custom tucked harness from my dsm.
I used a flex braid kit I found on amazon for 35$ but next time I will be ordering my own stuff. I would rather use F6 braided sleeving from wirecare.com. Its split so you need not de pin connectors to snake the wires through.
Old Dec 17, 2011 | 12:10 PM
jerd_hambone's Avatar
Depending what you are going to run, you can remove quite a bit. You can end up with a very clean wiring harness.
I'll be going this route, but I'll be using almost nothing from the original wiring.
Old Dec 17, 2011 | 07:43 PM
Havoc's Avatar
isis mutli system for the win
82streetracer
Aug 23, 2015 09:28 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
