West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need Advice.. Fast...
Old Dec 8, 2011 | 08:43 PM
ArmAnirx7's Avatar
Found a FC turbo online with bad water jackets.. how much does it usually cost to repair this?
Old Dec 8, 2011 | 08:44 PM
trainwreck517's Avatar
Rx-hippie
$200-5k depending whats wrong with it.
Old Dec 8, 2011 | 08:52 PM
ArmAnirx7's Avatar
Thanks.. who can determine how bad it is..Or can you even determine it without taking much apart?
I just bought a fc na but I want a turbo..btw..I work in Torrance bro.. Which part of torrance are you from?
Old Dec 8, 2011 | 11:38 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
Rotary shops or experienced forum members. Theres a list of rotary shops on top of the section.
Yes, three ways to determine a coolant seal failure.
1- Burning of coolant, usually will smoke upon start up eventually you will have a fog machine literally.
2- You will find coolant/excessive water in the oil.
3- Is the obvious kind,leaking between or around the housings and iron.
How to fix this-
1- full Rebuild
2- Depending on the condition of the internals and milage you can get lucky with a full O-RING KIT overhaul. Wich consist of new coolant seals ,oil seals,and misc internal orings.I suggest this if the engine has great compression and you are in a budget.
cost will vary from shop to shop. Also if theres any parts that need to be changed will also make a cost difference.
Alex
Old Dec 9, 2011 | 10:11 AM
ArmAnirx7's Avatar
How to fix this-
1- full Rebuild
Alex
Thanks Alex! I found a deal in Pasadena for a turbo 2 with bad water jackets for $1800 OBO.. I am so close to buying it
Old Dec 9, 2011 | 02:20 PM
Mn_Drift_FCon's Avatar
The nice thing about being forced to go through the engine like you will in this case is you can replace and upgrade common wear items and end up with a rock solid car. That's what happened with my 1st FC, consequently it was a very reliable car.
gusfd3s
15
Jul 27, 2007 03:08 PM
RorsRx7
Jul 11, 2007 06:58 PM
RxSven
May 19, 2007 11:12 PM
clonetropper
Nov 25, 2006 12:43 AM
PBK7
Jul 27, 2006 09:53 AM
