Power FC Could the PFC limit my boost?
Old Jul 19, 2002 | 07:04 PM
JAMMNN's Avatar
I am getting a concistant 8-5-8PSI boost ...I have tried everything all the troubleshooting even gone poor mans Non seqential nothing works could the PFC limit my boost or could I try increasing my base cycle to see if my boost increases?
Thanks
Old Jul 22, 2002 | 11:48 AM
take out the boost control solenoid.then the power fc cant control boost.take and put a 100 dollar dna manual boost controller in.and u can set it at whatever u want.
Old Jul 23, 2002 | 04:48 PM
Badog's Avatar
Re: Could the PFC limit my boost?
Thanks
Break the problem down. What did you change from the last time that the boost pattern was acceptable/different?
Did you check all the vacuum lines to the solenoids and the "pots?"
Did you double check them?
What about around the IC connectors? Losing boost through a ripped/slipped coupler?
What happens when you set the PFC to 0 boost? Are you getting anything?
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
