Drifting Discuss Drifting and drifting techniques here.
steering knuckle mod ?'s
Old Dec 1, 2011 | 03:22 PM
I fc3SLIDE's Avatar
so i recently met this guy with pretty much a full shop in his garage and we got to talkin about cars and i brought up my rx7 and he said if i wanted i could use anything i wanted such as pipe bender his miller tig machine and i wanted to take my knuckles and weld them up but how much do you cut off of them and so forth if you guys could post pictures of your knuckles possibly with a stock one next to it and any other thing i would need to know before doing this would be greatly appreciated thanks in advance
Old Dec 1, 2011 | 04:09 PM
vosko's Avatar
Just Call Me Terminator!
i would be real careful doing knuckles, do them wrong and they snap
Old Dec 1, 2011 | 05:22 PM
mikerbike's Avatar
Dreamin' of Rotary
https://www.rx7club.com/drifting-226/steering-knuckle-mod-moar-angle-766836/
Old Dec 1, 2011 | 05:25 PM
mikerbike's Avatar
Dreamin' of Rotary
I read that whole thread and couldn't find any info on reducing ackerman at lock. However, on another forum, someone posted the Wisefab kit for BMW E30/36, also front steer cars, and my thoughts were confirmed. Move the outer tie rod pickup inward to reduce ackermkan at lock. The knuckles TurboIIrotor made and sold seem to be exactly what you'll need to do. Good luck.
Old Dec 1, 2011 | 06:05 PM
sil8ty's Avatar
You want to move the pickup point outward(towards the rotor) if you are looking for less ackerman.
I've gone through 4 versions of my knuckles and I love the latest ones.
http://www.youtube.com/watch?v=iVleRnIwEu4
I could make you some if you'd like.
Old Dec 1, 2011 | 06:47 PM
mikerbike's Avatar
Dreamin' of Rotary
That's how it is on rear steer cars. And I'm inclined to believe you more than most. However, that video doesn't have anything to do with ackerman.
Is this picture, it shows the tie rod pickup moved inward, bad for S13. But this is a front steer car, like FCs.
http://www.burnout.lv/forums/downloa...hp?id=7122&t=1
I could still be wrong. It's just nobody's posted anything against my findings, except you.
Old Dec 1, 2011 | 06:49 PM
mikerbike's Avatar
Dreamin' of Rotary
Crap. I should have just posted the whole thread.
http://driftime.ee/foorum/viewtopic.php?f=52&t=1617
Old Dec 1, 2011 | 10:46 PM
sil8ty's Avatar
I cut my knuckles shorter and also moved the points out as far as they would go before hitting the rotor. This gave me way less ackerman.
Moving it outward will give you less ackerman. You can also just simply shorten the pickup but keep them in the same *plane* as the original points and it will move take away ackerman.
I just spent a bunch of time on solidworks modeling it up and the numbers are working.
It's the same for a rear steer car like a 240 mainly because of where the rack is positioned.
Old Dec 1, 2011 | 11:01 PM
I fc3SLIDE's Avatar
so basically chop it off quite a bit and stick it out as far as possible and weld like a mother ****** is what you guys are sayin
Old Dec 1, 2011 | 11:26 PM
mikerbike's Avatar
Dreamin' of Rotary
Still doesn't make sense in my head, but I don't use a front steer car. Then i looked at MAX knuckles for another reference. I stand corrected.
You don't want to show anyone the models you drew up because it will take away from your business? Fair enough.
Old Dec 1, 2011 | 11:35 PM
theshdwconspracy's Avatar
Trash Talk
exactly. and just eye ball it too. You'll be close enough.
Old Dec 2, 2011 | 12:06 AM
I fc3SLIDE's Avatar
hahah nah ill make a jig and **** but no one has givin any detailed info yethow much do you guys cut off do you get rid of all the angle portion of the stock tie rod mount position or leave some basically just need to know how much to cut off now
Old Dec 2, 2011 | 12:15 AM
mikerbike's Avatar
Dreamin' of Rotary
That's probably something you should mess with as per your preference. I removed about 15mm from the 3 pairs I've modded for S13.
Old Dec 2, 2011 | 01:06 AM
I fc3SLIDE's Avatar
true i think im just gonna chop a good amount and hope for the best obviously it will be jigged up but will see car wont be moving for at least 4-6 months anyways
Old Dec 2, 2011 | 10:39 AM
sil8ty's Avatar
Oh no not at all. I can post some pics but a lot of the numbers will be "fake" just to show the theory behind how it works.
Old Dec 2, 2011 | 03:29 PM
mikerbike's Avatar
Dreamin' of Rotary
The theory behind it is what I'm really interested to see. After seeing the MAX FC mod, I believe you. I've just gone and confused myself trying to think about it. I'm a kinetic learner.
Old Dec 2, 2011 | 08:54 PM
I fc3SLIDE's Avatar
im not lookin for numbers just pics i need some sort of ideas i can careless if my first set sucks *** i just need a starting point.. and if you could explain ackerman in short terms so i dont go to overboard with that
Old Dec 2, 2011 | 09:16 PM
FrankieK's Avatar
Braps on Braps on Braps!
make a jig that bolts the knuckles down where the lower ball joint bolts up. line the steering flange up with the ball joint using a straight edge and decide how much you want to cut out. i read that a guy cut out over a inch. i went 3/4 of an inch with mine
Old Dec 3, 2011 | 11:48 PM
Zenki FC3S's Avatar
\\TRASHTALK//
measure twice, cut once...
then TIG, dunzo.
have fun not spinnin out
Old Dec 4, 2011 | 09:32 AM
I fc3SLIDE's Avatar
well gonna wing it wil post some pics after there done of how much angle ive got out of just doing the knuckles
Old Dec 4, 2011 | 01:49 PM
OC DEBO's Avatar
TX
Where i come from, those are famous last words haha
Old Dec 4, 2011 | 05:16 PM
driftfcbuckey's Avatar
RX7-Factory
Position the end link slot more flat as opposed to (the end link bottom) angled towards the rotor.
Flap disc the sides of the spindle knub flat on the rotor side so you get more space to push out but leep in mind the position where the heim joint/end link will be at when mounted with the rotor on. If the end link rubs rotor you can machine a groove into the inner side of the rotor to get that little extra clearance.
Old Dec 4, 2011 | 05:19 PM
RX7-Factory
**** jigzzzz. Eye ball that ****. Mine took less than 30 mins start to finish.
Old Dec 4, 2011 | 05:48 PM
I fc3SLIDE's Avatar
ill have clearance but not much
Old Dec 4, 2011 | 11:38 PM
EPD's Avatar
EPD
lmao the info in this thread is golden.... shower.
