Snail's ongoing electrical thread
Old Nov 30, 2011 | 05:42 PM
snail_style's Avatar
Hey guys, so just a quick run down. I'm currently cleaning up/rewiring my series 4 RX7 where necessary, and removing everything i don't require. The end plan to have no radio/speakers and inplace of this either run a group of gauges in the centre of the dash, or some form of touch screen that can monitor all the incoming sensors(if you know of anything that can do this, please lemme know), along with a wideband a/f meter.
So far i've gotten the dash out and stripped the old alarm out, along with the speaker/radio unit. But i've ran into a few bits that have me puzzled, and i will be adding more to this as i go on, because i get puzzled alot.
There's a few things i've run into... I have looked through wiring diagrams but can't find any of it.
1. Not sure what both these connectors do. The first picture is under the driver's seat and there are two of them. The second picture is in the wiring harness along the driver's side scuff panel.
2. In these two pictures, there is a black/green wire & black wires going into the T-plug, red/green & black wires which are snipped as they were for the alarm, also a black/green & black/yellow wires into a two pin connector flat housing. What are all those for and is that node point standard?
3. There is button type switch that was fitted in the glovebox, it has red/green & black wires running to it which were soldered into aftermarket wiring running up to the button as you can see.
4. Is this clump of wires for the original radio?
5. This t-plug with yellow & black wires. What is it?
6. These blue/yellow & blue/red wires, what are they for?
7. Where can i get this microtech plug from? I've tried Jaycar and another place and they couldn't help. Waiting for a response back from Microtech.
firzen
Sep 15, 2015 12:04 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
