Super AFC Area is for discussing the Apexi Super AFC
Super AFC SAFC2 with a S4 NA to S5 intake swap
Old Nov 27, 2011 | 11:09 PM
Sgtbaker's Avatar
Rotorhead
So I have a 88 NA and I had my SAFC2 all set up and my car was running fine.
This weekend I installed a S5 Intake manifold and T2 secondaries and ever since than I can not get my car to run smoothly. It does not decel smoothly and lurches when i ease off the gas to shift. It also will "sputter" (i guess this is the best word to describe it) when I am in gear and holding the throttle down any less than 81%.
I know it is connected to the SAFC as when I disconnect it and jumper the yellow and white wire it works fine. Do I need to change the settings to reflect those of an S5 (06,06) instead of the S4 settings (05,05)?
Old Nov 28, 2011 | 12:31 PM
Sgtbaker's Avatar
Rotorhead
Well since I got sent home early from work for missing the safety meeting I guess I can try and mess with the settings. I also think I have a vacuum leak which could be causing the problem.
Azevedo
26
Mar 1, 2019 09:19 PM
Wicked93gs
Aug 23, 2015 10:14 AM
Engine stand ready
Aug 14, 2015 10:26 PM
