A/C and P/S belts wont come off!
Old Jul 19, 2002 | 01:22 PM
krackerx7's Avatar
Angry A/C and P/S belts wont come off!
im trying to get the A/C and power steering belts off of my 88' GXL and they wont budge theres new belts on there from the previous owner so im pretty sure a shop did it. and i took out the long bolts behind the pullys and it dosent budge................help!
Old Jul 19, 2002 | 01:28 PM
blu_gxl's Avatar
did you lose the pullies?? the bolts on the bracket that hold the pullies losen the pullies(move them down) this will enable you to remove them.
james
Old Jul 19, 2002 | 01:34 PM
jimmyv13's Avatar
Round&Round not Up&Down
There's a bolt that runs through the center of each tensioner pulley. It must be loosened to get the belts off. 17mm or 19mm........
Old Jul 19, 2002 | 01:38 PM
No7Yet's Avatar
Loosen the nut on the front of the pulley,
Loosen the tensioner bolt (the one on top of the bracket),
if it doesn't start to slack, tap on the tensioner bolt with a mallet (not a hammer),
remove belt.
Installation is the reverse of removal.
Brandon
Old Jul 19, 2002 | 01:45 PM
Turbonut's Avatar
As above stated loosen the bolts that go through the center of each pulley. After bolts are loosened you would turn the rod, 10mm I believe, and that will move the corresponding pulley.
Old Jul 19, 2002 | 07:08 PM
krackerx7's Avatar
i removed both bolts in back already thinking they world move......wrong and ive tried loosining the bolts but they dont budge. this shouldnt be this hard.
Old Jul 19, 2002 | 07:10 PM
Silkworm's Avatar
Has been.. hangin' around
The bolts are important, but the NUT holding those idler pulleys on are also important. Loosen that nut, then you should be able to move the idler up and down with those bolts.
(All IIRC, it's been 5 years since I had AC or PS)
PaulC
Old Jul 19, 2002 | 08:35 PM
krackerx7's Avatar
but they wont budge im trying to get the power steering belt off so i can get to the AC better but it wont budge and its starting to strip even with the right size socket. im thinking im just going to cut them off and worry about it later.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Coochas
44
Nov 5, 2019 11:08 PM
Robrods64
Oct 2, 2015 07:56 PM
Turblown
Sep 30, 2015 05:58 PM
