M2 Coilover construction
Old Jul 19, 2002 | 12:13 PM
amp's Avatar
amp
old yella
are they rebadged ground controls... ?
Old Jul 19, 2002 | 01:56 PM
gfelber's Avatar
As far as I can tell. They look identical except for the finish. And, of course, M2 uses Eibach springs.
In other words, neither product appears to be superior, although if you get M2's, I strongly recommend greasing the collar bolts or replacing with better hardware as they rust easily (and can get jammed in the collar).
Gene
Old Jul 19, 2002 | 02:06 PM
amp's Avatar
amp
old yella
GC primarily uses Eibach as well....
Old Jul 19, 2002 | 02:22 PM
1FooknTiteFD's Avatar
Ghost Ride the Whip
anyone know the spring rates for the ground controls on the eibachs?
Old Jul 19, 2002 | 03:49 PM
ARD T2's Avatar
I believe the FD's standard GC Eibach ERS rates are 550/450 respectively.
Rishie
Old Jul 20, 2002 | 05:37 PM
gfelber's Avatar
Rishie
Yep- that's the recommended rate. You may want to adjust this, however. I use 650 front and 450 rear. Some like softer rates as well. Do a search on spring rates- lots of good information.
Gene
Old Jul 21, 2002 | 12:33 AM
Silver93T's Avatar
Braap Braap Braap BOOM!
Are you talking about the coilover kit or the true coilovers? You can secify any spring rate you want. I'm runing 550/450lb now. Might go a bit stiffer in the future. Does the 650 up front make it understeer more?
Old Jul 22, 2002 | 05:52 PM
gfelber's Avatar
We were discussing M2's coilover "kit" and GC's. Of course, you can get any spring rate you want.
I use the 650's up front primarily due to suspension settings and tires/wheels (18x10 all 4 on 285-30s). This reduces understeer, particularly at auto-X. Very much like stiffening the front anti-roll bar (ARB), but with stiffer front springs and the same ARB setting you, in effect, reduce the front suspension's ARB dependence.
Gene
