Sponsored by: CARiD
Blew my first rotary?
Old Nov 21, 2011 | 05:49 PM
ImpartialMouse's Avatar
Went to start my car this morning and it sounded fine cranking then it kinda felt like it broke loose and its spinning way to fast now. Does loss of compression cause this?
Starter sounds really high pitched.
I tested the compression about 6 months ago and I had like 80-110 on all rotor faces. Now it is reading 50 on all 3 front faces and like 5-10 on the rear.. Kinda hopin I was doing something wrong.
Any info?
Guess its a perfect time to swap the turbo II drivetrain if I can find it.
Old Nov 21, 2011 | 11:08 PM
RotaryEvolution's Avatar
Sharp Claws
probably carbon stuck seals.
Old Nov 21, 2011 | 11:19 PM
Is this fixable in anyways without tearing the engine down?
Old Nov 21, 2011 | 11:21 PM
Sharp Claws
add about a tablespoon of MMO to each chamber and reinstall the plugs and turn it over. if that doesn't work then try pull starting it. run it until it warms up then hopefully it is all ok to shut down.
if you get it started i would recommend a water or carb cleaner treatment on the engine to decarbonize it.
Old Nov 21, 2011 | 11:26 PM
Car runs really rich so I say its a good possibility. This may sounds stupid but whats MMO?
Your post just made my day.
Old Nov 21, 2011 | 11:41 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
Marvel Mystery Oil =MMO
Old Nov 21, 2011 | 11:46 PM
Sharp Claws
what he said^
you can find it at most any auto parts store.
Old Nov 22, 2011 | 07:33 AM
Alright I'll check my local store today! I'm honestly in there more than anybody =/.
How exactly do you do a water or carb cleaner treatment? Would a seafome treatment or MMO in the gas tank do about the same thing?
Old Nov 22, 2011 | 12:30 PM
Just realized how I spelled seafoam. I am not stupid just wasn't thinking haha.
Old Nov 22, 2011 | 12:55 PM
Sharp Claws
if it is carbon sticking then you don't want to use a method that takes several hundred miles to process. basically the carbon that naturally builds up negates it anyways.
Old Nov 22, 2011 | 03:09 PM
So how would I get rid of the carbon quickly?
Old Nov 22, 2011 | 03:19 PM
Nevermind I did a search haha. Will do the water treatment if I can get it running.
Thanks for all the help Karack and I will let you know the results!
Old Nov 22, 2011 | 05:05 PM
Karack you really saved me a lot of money! That MMO worked great and I did a good water treatment on the engine =)! Took a little persuasion but after two days of constant abuse to my yellow top and starter (unflooding and flooding again), pushing the car over 20 mph down the road trying to get it started, I finally just casually cranked it over and it fired up playing with the throttle a little. It's still running as we speak but starts back up fine. I'm gonna run the sea foam in the tank to get another good amount of the carbon out.
I am a very happy person and had a very accomplished day! Some of the people on this forum are very helpful and I always see you (Karack) stepping up and helping people like me with no benefit to yourself. Thats what makes this a great community.
I recommend an Rx7 to anyone for a first car if they are in high school or not. Its a great experience fixing the things that go wrong and learning as you go.
Old Nov 23, 2011 | 08:47 PM
sideways-FC's Avatar
LOPEY IDLE
yea I just happend to choose an rx7 as my first car when I was 16 in high school. Best choice I ever maid in my life. and yes the club is a very amazing place.
Old Nov 23, 2011 | 10:13 PM
Sharp Claws
i do get the benefit of referrals, which happens to be the majority of my customer base. you're welcome and just keep me in mind if you ever do really need an engine built.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
