Megasquirt Phase Injection
Old Nov 15, 2011 | 02:03 PM
kutukutu1's Avatar
FL Phase Injection
Has anyone done phase injection with the megasquirt? Just a curiosity question
Old Nov 15, 2011 | 08:06 PM
muythaibxr's Avatar
MegaSquirt Mod
Do you mean sequential injection?
Ken
Old Nov 15, 2011 | 09:20 PM
kutukutu1's Avatar
Not exactly sure if sequential means the same as phase, but what I mean is like 2 injectors per rotor and the one injector sits up top and another sits very close to the inlet so basically the one fathers away squirts at lower one and after a certain rpm the second one close to the inlet squirt while the one on top is till squirting. Don't know if I explained what I mean very well. But I was told by a British engineer down here in Miami that the top one would allow better atomization and better idle while the one that's very close to the inlet would make more power in the high end. sorry for the long post, could not explain it any shorter.
Old Nov 16, 2011 | 03:55 AM
Eagle7's Avatar
Nope, you're talking about staged injection. The primaries are used at idle and low load and the secondaries are added at high load/RPM. That's a standard feature in Megasquirt used with most rotary configurations and many other cars. But you've reversed which is which - the primaries are close to the inlet and the secondaries are further up.
If you're interested in MS you can read lots more here:
http://www.msextra.com/doc/index.html
Old Nov 16, 2011 | 03:48 PM
kutukutu1's Avatar
k cool thanks, so i just had them backwards. i knew that the megasquirt came with staged injection but didnt know it was the same as phase injection just different way of saying it.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
