apexi avcr ????? Boost questions
Old Jul 18, 2002 | 11:20 PM
gz91rx7's Avatar
Ok my 89 T2 is going to be at the track tomorrow and I want to get some good times. Right now I am running on my autometer gauge about 6 psi. I have the apexi avcr and I was thinking about adjusting the psi so get more out of my car but I dont want to **** anything up. Please help!!
Here is my mod list:
Engine Mods:
- Trust Airnix Filter
- Greddy Extreme 60mm Exhaust
- Custom 3" Turbo Inlet
- Disabled secondary throttle plates
- 3" Hi-Flo Dynomax Catalytic Converter
- 3" Racing Beat Downpipe
- Hybrid Turbo Garrett T04B (Compressor) / Hitachi HT18 w/ ported wastegate
- Apexi dual chambered BOV
- Mild Street Port (intake and exhaust)
- Rebuilt block w/ FD corner seals and springs (4-5K miles)
- Racing Beat Engine Brace
- Magnacore 8.5mm Wires
- MSD 6A Ignition Pack (Leading Coils)
- HKS FCD
- Dual Pulley (Alternator)
- Apexi ACV-R Boost Controller
Suspension Mods:
- Suspension Techniques Front Sway Bar
- Tokiko Illumina Shocks
- Trust Upper Strut Tower Brace
- (4) 17x8 (40mm offset) Rota Stage 5 Rims
- Dayton ZR Tires
- 215-45 (front)
- 245-45 (rear)
Transmission Mods:
- C's Short Shifter
- Mazda Trix Competition Mounts (new)
- Racing Beat Lighten Steel Flywheel (new)
- OS Giken Clutch (FD Stock Clutch) (new)
- ACT Heavy Duty Pressure Plate (new)
- Redline Oil in Tranny
- SS Braided Hydraulic Clutch Line
Fuel Supplement:
- FD Fuel Pump
- (2) 720cc Injectors in Secondary
- Apexi Super AFC
Thanks to everyone!
Old Jul 18, 2002 | 11:26 PM
Scott 89t2's Avatar
SOLD THE RX-7!
without a front mount intercooler I wouldn't go over 8-10psi. but you also have to be weary of your s-afc settings.... and not run lean.
with A FMIC and some good tunning you would have a VERY fast car.
Old Jul 18, 2002 | 11:35 PM
gz91rx7's Avatar
I have the old safc with ***** and they are currently all set just below 0. If I give it more boost I should also give it more gas correct? as much info as you could give would be the best!
Thanks!!!!
Old Jul 18, 2002 | 11:51 PM
gz91rx7's Avatar
Also on the avcr it is reading 1.00 what rating is that and if I adjust it up what should it be?
thanks!
Old Jul 19, 2002 | 12:26 AM
Scott 89t2's Avatar
SOLD THE RX-7!
it's probably in bar. 1 bar is 14.7 psi...
Old Jul 19, 2002 | 12:33 AM
gz91rx7's Avatar
Well if that is true then shouldnt my gauge be reading alot higher than 6 psi??? I am really confused??
Old Jul 19, 2002 | 06:36 AM
IAN's Avatar
IAN
Rotary Reborn!
First 1kg/cm2 us 14.7psi.
What gauge are you reading 6psi??
Your are in a dangerous place.
Last year I went to .9, I blew my engine allmost instantly but I didn't have bigger secondarys.
What is your duty cycle set to? What are you settings for boost A and B.
You should be able to control your boost if you have an adequate wastegate. Who rebuilt your turbo?
Other then that you have a nice mod list.
My car boosts to .85 before I have to back off or at least 12psi. I have a VSPL Greddy FMIC but just a remapped ECU and 3rd gen fuel pump. No other fuel mods.
Ian Skacel
88 10th AE
Old Jul 19, 2002 | 12:58 PM
gz91rx7's Avatar
I am reading my autometer gauge in my pillar!
Also I dont know how so set my duty cycle or what to even set it to! That is why I had this post.
My A setting reads 1.30 and my B setting reads 1.00
I think that is in the mm/hg though
Old Jul 19, 2002 | 05:59 PM
IAN's Avatar
IAN
Rotary Reborn!
1.3 is like 19psi.
Who set up you AVC-R.
I'm no expert but that sounds like your going to pop your motor..
Ian Skacel
The duty cycles is set under settings. To much slow response and less boost. To much you get spike or creep.
While setting parameters under A press Right arrow to see settings under boost settings.
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
