LSD upgrade?
Old Nov 3, 2011 | 04:36 PM
Djonyx's Avatar
LSD upgrade?
I don't know if this would be the right section for this! Any way I'm in the process of hunting for a TurboII differential but the prices seems to be expensive for a used differential and not certaind of the condition which might cost more. So I would just purchase a brand new lsd core and install it on a open differential carrier. I'm not quite sure what else do I need to complete the upgrade.
Turbo II stubs
Turbo II half shafts
Bearings
or I would need a turbo II differential pumpkin?
I am confused right now!
Old Nov 4, 2011 | 04:56 PM
swilson@assetworks.com's Avatar
Old and In the Way
Probably not the right section...
The TII gears and LSD don't fit in the NA housing.
To put a T2 diff in an NA car with an NA trans you will also need a custom drive shaft.
Else, you could find an NA LSD from a GTU or GTU-S (look for an NA with 5 lug wheels) that will use your existing drive shaft and axles. DO a search in the 2nd gen section.
Old Nov 7, 2011 | 04:41 PM
Djonyx's Avatar
Thanks! I found an after market 2 wayLSD for my n/a diff.
ls1swap
Jun 3, 2024 03:25 PM
