Useful Equasions...
Old Jul 18, 2002 | 04:29 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Useful Equasions...
I would like to start a thread specifically to be archived that is basically nothing but a collection of auto-related equasions. Everybody- Contribute to this, whatever ya got.
Maybe mar3 has the "magic boost" equasion (hint-hint), and someone else has the latest "automobile depreciation" equasion.
Anything pertaining to cars, MPG, power and performance, monetary value...whatever.
It'll be a data thread to theorize about stuff, and a great way to start cool arguements!
What say the High Council?
I found this that I wrote down forever ago; don't even know where I got it...
Vs= 3[the square root of (3Reb)]
Vs= Swept Volume
R= Generating Radius
e= Eccentric Radius
b= Rotor Depth
(Don't ask me how to use this particular equasion! )
And can someone please show us how to type the symbol for "square root"?!
Old Jul 21, 2002 | 05:50 PM
inittab's Avatar
I read your email
Re: Useful Equasions...
You mean this? √
Old Jul 21, 2002 | 06:16 PM
Hans's Avatar
ill get easy ones!!!
Pressure ratio is
(14.7+boost psi)/14.7
Air flow rate is (cid * rpms * 1.5(.5 for boingers) * Ev)/1728= XXX cfm's
*******(i hope the 1.5 is right, thats what I think should work and i get some realistic numbers)********
using
69.9cid (1.146*61) 1 liter is 61cid
7000rpms
85% for Ve
I got 361cfm
does this sound about right for a mostly stock Rex?
to get cfm for boosted motors multiple times PR
for example
PR 1.5(~7psi) * 361cfm = 542cfm
also when comparing to a compressor flow map that is in Pounds per Minute
(lbs/min), multiply CFM by 0.069 to convert CFM to lbs/min
hope this helps,
oh and most of this is from Corky Bell's book btw
Old Jul 21, 2002 | 06:27 PM
Hans's Avatar
Good site, mostly boingers but good site non-the-less
http://www.prestage.com/carmath/
Old Jul 22, 2002 | 06:18 AM
MikeLMR's Avatar
'Last Minute' Rallying
Don't forget the most important Equation
Force = Mass x Acceleration
therfore Acceleration = Force/Mass
therfore less mass = more acceleration for the same force
= one of the cheapest ways to make a car go faster
Old Jul 22, 2002 | 08:22 AM
crankit's Avatar
How did this thread get a 5***** rating? Nice idea but I don't agee with the rating so early.
Old Jul 22, 2002 | 09:09 AM
Orange!FD's Avatar
Horsepower = (Torque * 2*pi * RPM/60) / 550
or
HP = Torque * RPM / 5252.11
For example HP = (170 ft-lb * 6.28 * 7400 rpm /60) / 550
HP = 239.5
Old Jul 22, 2002 | 09:31 AM
MikeLMR's Avatar
thats better orangeFD... I was about to correct you ... 1000ftlbs at 7400rpm = >1400 HP !
you can simplify that equation to
(Torque x Engine speed) / 5252 = Horsepower
this also explains why dyno print outs cross at 5252 Rpm presumuming that H.P and torque are on the same scale
Old Jul 22, 2002 | 09:34 AM
Orange!FD's Avatar
Yeah, since it isn't late here, my excuse is: It's early.
