3/8" One-way Check Valves?
Anyone know where to get these locally? The previous owner of my RHD replaced the brake booster line with a silicone line not knowing there was a built-in check valve. I haven't had any luck sourcing an OEM replacement as the RHD line is different then the LHD one. So just thinking of putting an external check valve in the silicone line.
I've tried Napa, parts source, and canadian tire. They only have the little ones for small vacuum lines.
thewird
thewird
Local hydraulic store. If they don't have it (oddly they are hard to find) then a sprinkler store will.
You can also get a 2nd gen brake boost hose and make it fit. The check valve is built in.
Tem120
Sep 7, 2015 09:53 AM
