driveshaft flanges??
Old Jul 18, 2002 | 12:26 PM
crankit's Avatar
Are driveshaft flanges interchangeable ? Switching 3rd member but flanges different.
Old Jul 18, 2002 | 12:33 PM
damon's Avatar
You can swap the flange from one to the next , or you should be able to swap the driveshaft along with the diff
peace
Old Jul 18, 2002 | 12:46 PM
crankit's Avatar
Need to swap the flanges. Using a 84 manual think the other might be from an auto? Larger bolt pattern. Don't have the driveshaft to it. Flanges interchange?
Old Jul 18, 2002 | 12:50 PM
damon's Avatar
yes , save your self a mess and order a new seal from mazdatrix or somthing . if not that 20 yr old seal will probably leak
peace
Old Jul 18, 2002 | 01:36 PM
crankit's Avatar
Thanks . Now the work!
Old Jul 18, 2002 | 01:38 PM
MarkPerez's Avatar
Tennis, anyone
if your changing the 3rd member..remember that the
axle splines are different size's.depending on the rearend housing you have,,' ie' disks/drums you may
want to grab the axles too match the 3rd member.
i know there are different spline sizes, i don't know
the years,,or is it models 'ie' GS,GSL,,etc
Old Jul 18, 2002 | 06:46 PM
crankit's Avatar
Only thing I lack is the other driveshaft. So as long as the flanges are interchngeable I should be all right.??
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
