Putting a s4 tranny on a s5 engine
Old Oct 25, 2011 | 10:04 PM
The Wildchild's Avatar
Do all you need to do is match the same series flywheel as tranny?
Old Oct 25, 2011 | 10:26 PM
MIDNFauciUSN's Avatar
Roll FIS green
I BELIEVE you don't even have to do that.... Just minor wiring mods actually...
Old Oct 25, 2011 | 10:53 PM
Derekcat's Avatar
Rotary Zealot!
MIDNFauciUSN >> Yep! The engine/flywheel have to match, the transmission only has to be NA or Turbo-matching the engine. [But make sure you have the correct crossmember and Y-bracket for your transmission!]
Old Oct 26, 2011 | 11:29 AM
farberio's Avatar
NASA-MW ST4
The flywheel series must match the engine. (S4 to S4) (S5 to S5)
The flywheel type must match the transmission. (TII to TII) (N/A to N/A)
The transmission crossmember must match the transmission series. (S4 to S4) (S5 to S5)
Old Oct 26, 2011 | 12:03 PM
87 t-66's Avatar
not a drifter
Originally Posted by farberio
the flywheel series must match the engine. (s4 to s4) (s5 to s5)
the flywheel type must match the transmission. (tii to tii) (n/a to n/a)
the transmission crossmember must match the transmission series. (s4 to s4) (s5 to s5)
+1
Old Oct 26, 2011 | 03:34 PM
Perfect thanks
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
Wicked93gs
Aug 17, 2015 12:14 PM
