did i just ruin my vert wheels
Old Oct 25, 2011 | 05:24 PM
Driftology's Avatar
i decided to do some diy wheel restoration today and i think i messed up. i read in this forum that the vert bbs wheels don't have a clear coat on the lip. so i figured i could use some super fine sand paper to get off some of the oxidation i have on them. i few minutes of wet sanding and a dark spot showed up. dried it off and buffed it and now i have a spot with a mirror finish in it. is that spot the way the whole lip is suppose to look or did i take off a finish i didnt know about?
Old Oct 25, 2011 | 05:26 PM
RotaryEvolution's Avatar
Sharp Claws
most all aluminum wheels have clearcoat, you got punked. send them off to be professionally resurfaced and re-clear coated. most shops charge about $60-80 per wheel to refurbish them but they should look like new afterwards.
Old Oct 25, 2011 | 06:57 PM
Driftology's Avatar
that sux, well i guess i would need to get them resurfaced either way. thanks for the info
Old Oct 25, 2011 | 08:05 PM
marclong's Avatar
I stripped my rims and buffed them out. They look awesome. Just do not use wheel cleaner ever again
Old Oct 25, 2011 | 08:17 PM
marclong's Avatar
Here is a picture. Of course the wheels have never seen rain in a decade, And i polish them up all the time. But they look great. about 8 years ago my wheels looked so bad because half of the clear was coming off, I bought paint stripper and took the clear off. Then buffed them up with mothers polish. If wheel cleaner ever touches them they go to ****. So i can only use regular soap and water to clean.
Attached Thumbnails did i just ruin my vert wheels-2011-10-25_21-06-36_336.jpg
Old Oct 25, 2011 | 08:22 PM
marclong's Avatar
Better picture maybe. Light is low in the garage tonight.
Attached Thumbnails did i just ruin my vert wheels-2011-10-25_21-19-51_890.jpg
Old Oct 25, 2011 | 09:01 PM
Sharp Claws
most people don't have the patience for polishing, it's also a good idea to clear so you can clean the wheels however you want.
Old Oct 25, 2011 | 09:02 PM
Driftology's Avatar
that looks super clean! im too lazy for that much work tho
Old Oct 25, 2011 | 09:15 PM
marclong's Avatar
Yet not a big deal to polish with a dremel or die grinder with buffing wheel. But like I said its not a daily driver anymore. I still think they look better than a clearcoated wheel. But clearcoated is better for maintenance and all.
Old Oct 25, 2011 | 09:32 PM
GregW's Avatar
~!@#$%^&*()_+
To the original poster, if your lazy, try using some rattle can clear on that spot. It wont be good as new but I bet it will be damm close.
If you like the results, scuff the ring all the way arround, mask and clear coat.
Old Oct 25, 2011 | 09:37 PM
Driftology's Avatar
good call
astrum
24
Nov 15, 2017 08:44 AM
