Differential Oil question
Old Oct 23, 2011 | 08:26 PM
88fcNA's Avatar
I recently pulled my diff and welded it. put oil in it while it was out. Put it back in and was great. till i remembered i forgot to replace the axle seals. Started to leak and get low on oil. b4 i parked it the diff started to whine under acceleration. did do that when there was a lot of oil in it.
I replaced the seals with my diff in my car. doesnt leak. kewl beans. buuuut how to i refill it? cant put it in the axle whole bc it comes back out at a point. even with the car tilted. its filled up to the very botten and 2nd drain plug up. i noticed a lil nut out something on top of the back of the diff when it was out and figured that may be a fill plug. now its in the car and theres no way of getting a bottle of gear oil up there. do i have to run a hose and pump it up? or what? also is the whining from low oil?
thanks
Old Oct 24, 2011 | 09:51 AM
Aaron Cake's Avatar
Engine, Not Motor
The diff has two plugs on the back: fill and drain.
Drain is on the bottom. Keep that one closed.
Fill is halfway up the case. With the car level, remove that plug and then pump gear oil into the case until it begins to overflow. It's something like 1.6 quarts. Reinsert fill plug. Done.
I hope that this welded diff is track only. Very unsafe on the street.
Old Oct 24, 2011 | 10:28 AM
88fcNA's Avatar
it is filled up to the 2nd plug (plug thats bout in the mid of the diff) but still whines. i dont accel hard/drive hard on the streets and i drive slow in the rain with it so it aint bad.
Old Oct 24, 2011 | 10:36 PM
REAmemiya_fan's Avatar
Passion for Racing
Quick thread jack> I am wondering why my open diff did this while trying go back up without the drive shaft hooked up... It would roll to a certain point then like lock up and stop. I don't know much about open diffs and since I had no intentions on reusing or selling it we just pushed the car back with it popping every few feet. I'm sure it wasn't at all good for it but we needed it out of the shop and have no wheel dolleys to prop them on.
Old Oct 24, 2011 | 10:48 PM
Wms10th's Avatar
10th Mazda - 10th A.E.
Something is broke inside, tooth off a gear, pinion, ring or spider gear tooth.
Old Oct 25, 2011 | 09:01 AM
Passion for Racing
Yea I figured thats what happened. I just didn't know what to think since it only happened in reverse and never did it until we had the drive shaft off. Oh well, you live and learn
Old Oct 25, 2011 | 09:53 AM
Aaron Cake's Avatar
Engine, Not Motor
If it's whining then something is wrong. Bearing damage or gear damage.
Old Oct 25, 2011 | 10:09 AM
AGreen's Avatar
Trunk Ornament
Did you hook the electrode to the case and weld the spider gears? If so, all that welding current went through the bearings to get to the spiders, and you've just damaged the whole thing.
Just something to consider when welding on cars...
Old Oct 25, 2011 | 11:06 AM
88fcNA's Avatar
I think he had it clipped to one of the 4 bolts in the casing that holds it all in.
Old Oct 25, 2011 | 02:27 PM
AGreen's Avatar
Trunk Ornament
Well... there's your answer
Old Oct 25, 2011 | 03:53 PM
88fcNA's Avatar
but y didnt it whine when there was lots of oil in it?
and i think ima just buy a LSD if its done for.
Do i need a lsd and half shafts to do that swap or what else?
thanks
Old Oct 25, 2011 | 05:21 PM
RotaryEvolution's Avatar
Sharp Claws
holy crap... do people not read the faq thread which has links to the factory service manual in it?
if you go with a turbo LSD unit you will need turbo half shafts and a modified driveshaft. if it's a non turbo LSD it is a straight swap from the same series car, if it is a different series LSD then you need the appropriate half shafts that came with it.
Old Oct 25, 2011 | 07:00 PM
AGreen's Avatar
Trunk Ornament
Old Oct 25, 2011 | 07:07 PM
PvillKnight7's Avatar
hahahaha tonight delivers the lolz!
Old Oct 25, 2011 | 10:38 PM
Passion for Racing
Btw, my open diff stopped doing the locking thing in reverse... So Idk wtf was up with that. And as for the OP, just save up for. KAAZ 2 way if you really want to drift a lot
Old Oct 26, 2011 | 12:50 PM
Sharp Claws
**** that, he can order the kaaz and send it to me since he might forget to put oil in it and wonder why it is making noise...
Old Oct 26, 2011 | 01:14 PM
88fcNA's Avatar
there is oil in it.
herpa derp
Old Oct 26, 2011 | 01:28 PM
Sharp Claws
you can't say you didn't ask for it.
Old Nov 4, 2011 | 04:43 AM
AmT_T's Avatar
Make It Happen!
Some ppl need a forum 101 crash course. - Edit - Most ppl
alphawolff
Nov 17, 2015 05:57 PM
