Sponsored by: CARiD
motor vibration issues
Old Oct 20, 2011 | 12:33 PM
power hungry's Avatar
3 rotor
Just bought a rebuilt s5 t2 motor from a guy and have some vibration issues. I know its motor related as it vibrates when I free rev it. smooth at idle but get higher in the rpms and vibrates pretty bad. My thught is counterbalance and flywheel mismatch but a little concerned that maybe he mismatched parts inside. Am I on the right track with the flywheel and counterbalance weight or am I screwed and need to pull this motor apart and balance it.
Old Oct 20, 2011 | 04:12 PM
3 rotor
These are the markings pulled from the flywheel castings that I could read with a mirror.. HY1 and 1a3n. Do those tell me anything?
Old Oct 24, 2011 | 01:38 PM
Kentetsu's Avatar
I ran into that exact issue with a 12a (mismatched flywheel). It vibrated quite bad, bad enough that I knew right away that something was wrong. The thing is, I didn't have to rev it very high before it started shaking. Since yours is only doing this at higher rpms, maybe you have a different issue...
I think the flywheel is the place to start though (assuming you've already gone over motor/tranny mounts).
Good luck.
fastrx7man
33
Sep 2, 2015 09:42 PM
DaleJK
Aug 31, 2015 10:19 AM
befarrer
Aug 14, 2015 04:18 PM
andyvideopro
Aug 11, 2015 09:16 PM
