no heat
Old Oct 15, 2011 | 02:58 PM
mjedding's Avatar
Question no heat
i have a 88 and for some reason the car wont heat up i even put a new thermostst in it and the needel will bearly come off the cold mark is there anything to do to get the car to warm up more
Old Oct 17, 2011 | 01:39 AM
dwb87's Avatar
This is my social media.
Try posting this in the "2nd Generation Specific (1986-1992)" section.
Old Oct 17, 2011 | 10:24 AM
AGreen's Avatar
Trunk Ornament
Does your fan spin with some, but not a whole lot of resistance?
Old Oct 17, 2011 | 10:27 AM
RXSpeed16's Avatar
Theoretical Tinkerer
There is *probably* no need to try to raise the temp any more. Temp gauges on the series 4 cars (86-88) normally read about 1/4 ~1/3 when they get up to temperature and the thermostat opens. They switched the gauge setup later partly because many people had the same complaint you are stating here.
Old Oct 17, 2011 | 10:35 AM
Molotovman's Avatar
Ban Peak
Originally Posted by RXSpeed16
There is no need to try to raise the temp any more. Temp gauges on the series 4 cars (86-88) read about 1/4 ~1/3 when they get up to temperature and the thermostat opens. They switched the gauge setup later because many people had the same complaint you are stating here.
He's correct.
Your temp gauge will never read above 1/3 at normal temp.
Mine used to sit a hair above thethe line above C. As long as you're getting good heat inside the car, your car is running warm enough.
Old Oct 17, 2011 | 05:28 PM
mjedding's Avatar
but im not getting any heat at all
Old Nov 11, 2011 | 09:00 PM
st1llet0's Avatar
If you open the hood, is it warm? Do you mean the heater won't work? Have you checked that the coolant lines run to the firewall for the heater core?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
7upra
Mar 25, 2018 11:32 AM
