Fuel sock changing
Old Oct 14, 2011 | 02:42 PM
phound69's Avatar
Fuel sock changing
pumps out.
everything's disconnected, but I can't figure out how to get the filter off at this point.
Help?!
Old Oct 14, 2011 | 03:16 PM
RXSpeed16's Avatar
Theoretical Tinkerer
Take a pick or a similarly pointy tool and pry the 3 tabs up on the metal retaining ring. You show it in your picture at about 11 o clock from where the sock feeds the pump.
Old Oct 14, 2011 | 03:37 PM
phound69's Avatar
yeah, thought there was some mystical way of removing it. Dee de dee!!! Still won't start though. Fuel pump could hear operating when I jumped the yellow connector.
Old Oct 14, 2011 | 03:51 PM
phound69's Avatar
Did the procedure for de-flood. After a couple attempts, it started. Not very well, but it's still running ragged compared to what it should. The idle is rough, but near 1500, doesn't want to rev, goes to about 4k before it says no more and gets very ragged. how do I test the wires/coils for working? Multimeter use is in its infancy here.
Any other suggestions.
Old Oct 14, 2011 | 04:25 PM
RXSpeed16's Avatar
Need some more background on the car and condition. Was it sitting for a while, running good before being worked on, suddenly not working like it used to? Cutting out at 4k rpm is usually a sign the secondary injectors aren't working. They could be clogged or broken, have bad wiring, a fried ecu. For spark, turn off engine and remove EGI fuse. Pull a plug wire and insert metal object/spare spark plug and lay it on the block. Crank and see if you can see it arc.
Old Oct 15, 2011 | 12:28 AM
Rx7Ridah's Avatar
Yeah.... we need some background info like how long the car has been layer up, what/when did it start running poorly, are you just first getting it going and replacing the filter sock is one of your starting points.... so on and so on.
Anyhow run the course of full tune up, fuel filter and fuel pressure testing, then go onto vacuum leak/intake leak testing and repair, then onto electrical. When in doubt search and read all of these have been beaten to death.
Queppa
Nov 18, 2024 03:47 AM
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
