N3A7 ecu
Old Oct 12, 2011 | 02:08 PM
suck_my_rotor's Avatar
*Currahee Performance*
N3A7 ecu
Hey guys so i picked up a jdm s5 turboII engine with wiring harness and ecu, from what i have read the N3A7 is a 3rd gen computer? I have also read that its out of a 1992???? shouldnt my computer be an N370? Also forgot to mention, two of the connectors from the wiring harness plug into the computer.
Old Oct 12, 2011 | 02:26 PM
RotaryEvolution's Avatar
Sharp Claws
it is for a series 6 FD3S, no it won't work in any second gen, yes you should have an N370 which are rather difficult to find. it could have been modified to work but the FD harness is completely different than the S5 harness connectors.
are you sure you didn't get an REW by mistake?
Old Oct 12, 2011 | 02:40 PM
It is an s5 turbo engine and wiring harness, As you can see in the pictures two of the connectors plug into the computer, the third connector is too big, which looks like is goes on the far left of an n370 ecu.
Old Oct 12, 2011 | 02:41 PM
http://i1213.photobucket.com/albums/...011_220312.jpg photobucket sucks, it wouldnt load this one up.
Old Oct 12, 2011 | 02:42 PM
87 t-66's Avatar
not a drifter
you should have received a N374 ecu which is the JDM S5 ecu and often does not work with USDM vehicles.
Old Oct 12, 2011 | 02:45 PM
Sharp Claws
well they may have piggybacked the FD ecu but i really have no idea why they would bother unless they were trying to get it to mock up higher boost with some supplemental fuel modifications. the japanese tuners do some crazy **** sometimes..
Old Oct 12, 2011 | 02:49 PM
Yeah, I'm pretty confused. is it possible for this computer to run my engine? if not, who wants to trade an n374 for this computer I'm stuck with.
Old Oct 12, 2011 | 02:51 PM
Sharp Claws
unfortunately the FD ecu's are pretty much worthless and the N370 is quite sought after due to it being needed for an S5 TII swap as you're doing with a very limited amount sold in the US.
i wouldn't run the FD ECU even if it was repinned to work, as it is configured to run up to 10-12psi and has a different injector configuration than the stock S5, which may also be worth looking into if it has upgraded secondaries. TIIs have 550's X4, FD has 550X2 and 850X2.
you may be better just getting an aftermarket reprogrammable ECU.
Old Oct 12, 2011 | 02:52 PM
j9fd3s's Avatar
Community Builder
more likely it just got mixed up at the junkyard.... N374 and N3A7 use a lot of the same letters/numbers.....
its possible to use the FD ecu on a 13B-T but its a LOT of work to hook it up, i've never seen it done with a STOCK FD ecu, its always a power FC, they love the power FC over there.
http://www.youtube.com/watch?v=c2Oliq1znfk this P port 3 rotor cosmo is running THREE power FC's.
Old Oct 12, 2011 | 02:55 PM
Ok, well Thanks for the help, I'll call the company I got it from and have them send me the right computer.
Old Oct 12, 2011 | 06:06 PM
K-Tune's Avatar
FD Daily
Maybe just the cover has been swapped?
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
