SevenStock Archive Look here for threads from past SevenStock events.
Things to See @ SS14
Old Oct 11, 2011 | 12:01 AM
Bern's Avatar
We hope you all are getting excited about SS-14... we wanted to give you a little preview of what one might see this year.. what about a 12 ROTOR motor!!
I also hear that one of the top vendors in RE community might be showing their prototype 5.5 pound cast titanium/aluminum/steel rotors!!
-Bern
Old Oct 11, 2011 | 10:25 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Le' drool....
Old Oct 11, 2011 | 01:51 PM
-xlr8planet-'s Avatar
I has an emblem
what the ....
Old Oct 11, 2011 | 10:32 PM
fd3s777's Avatar
Registered User
That is sickest thing I ever seen!
Old Oct 12, 2011 | 12:54 AM
Bigyellowcat's Avatar
Thanks. There is alot of sleepless nights in that engine. Still working on it now trying to get it put back together for seven stock. How about a show of hands if you want to hear this thing run at seven stock?
Attached Thumbnails Things to See @ SS14-7.jpg   Things to See @ SS14-9.jpg   Things to See @ SS14-22.jpg   Things to See @ SS14-20.jpg
Old Oct 12, 2011 | 12:58 AM
REPU_74's Avatar
What type of engine management r u running on it???x3???
Old Oct 12, 2011 | 02:03 AM
Pectel
Old Oct 12, 2011 | 02:21 AM
Bern's Avatar
Thanks to Tyson for bringing this beast out!!!
-Bern
Old Oct 12, 2011 | 02:43 AM
Rotary13B1's Avatar
I want to hear this beast run! Run it at SevenStock14!!!
Old Oct 12, 2011 | 10:59 AM
13x's Avatar
13x
Sin City Rotary
hand
Old Oct 12, 2011 | 02:28 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
my dick is going to blow out like the end of a hotdog in the microwave too long...
Old Oct 12, 2011 | 03:29 PM
Hear it run? I want to hear you bolt it into my car!
Old Oct 12, 2011 | 07:34 PM
prrex4ever's Avatar
Now What?
DAMMMN! that is SICK!
Old Oct 15, 2011 | 03:04 AM
TheAbsence's Avatar
s4 Pride
You HAVE to run that thing at Sevenstock!
Old Oct 21, 2011 | 07:27 PM
I thought there would be more people that would want to see this thing out there. Is anyone comming through Missouri going to seven stock?
Old Oct 21, 2011 | 11:19 PM
94socal7's Avatar
*whispering*
If you bring it, they will come.
Old Oct 25, 2011 | 01:28 PM
boyee's Avatar
keep it original!!
HAND!!!!!
Old Oct 25, 2011 | 04:07 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
I just saw this... son of a b...
Dude you gotta run it at ss14!
Old Oct 26, 2011 | 03:05 AM
well.... Its 3 am wednesday and I'm still working on the engine trying to get it ready for seven stock... Thanks James from pittsburgh ( not sure what he goes by on here) he was here helping me all day today but im not sure Im going to finish it in time to haul it all the way out there. I have worked on it all day and night for the last couple weeks and if i dont go to sleep for the next day I may finish it but then I would have to drive all the way to LA from missouri with no sleep.. this is why I was asking if anyone was going through here on there way? maybe they could drive and I could sleep? If I finish the engine in time I would still have to make a stand to put it on also.. So I'm trying still but I may not make it. I need to decide if I dont finish it but bring it out there anyway, or stay here and keep working on it and have it running this weekend?
here is a pic of the point Im at with the engine.. its pretty much together, the rotors and seals and sleves cranks stationary gears ect. are all in it. 56 tension bolts are torqued down, gear box is on and timed. intake and exhaust are sitting on it but not tight I dont have the intake gasket yet. and we made a change to my front bearing caps so im machining them right now, and just finished the rear output flange for the flywheel to bolt to. I was machining the balancer hubs and messed up and made them .001 over size instead of -.001 undersize to press on so now they are loose with no way to fix them. I think lack of sleep is making me make mistakes..
Old Oct 26, 2011 | 03:20 AM
Bern's Avatar
SLEEP SLEEP... bring out the engine as is... even if not running. SevenStock is as much about finished projects, as it is about the unfinished projects... the journey is what counts for us. So even if not totally done, there is a huge group of enthusiasts that want to see this engine and speak to you in person!!
-Bern
Old Oct 26, 2011 | 03:32 AM
TheAbsence's Avatar
s4 Pride
^ What he said. Bring the engine unfinished and get some sleep. We don't want any accidents as you're driving out here. Just promise to bring the finished engine next year!
Old Oct 26, 2011 | 10:26 AM
Ok, I'm going to get as much done today as I can then load it up and head out there. See you in a few days
Old Oct 26, 2011 | 10:30 AM
Drive carefully; completion requires survival!
Old Oct 26, 2011 | 02:56 PM
rotarydude's Avatar
Back in the saddle again
from MO
BYC,
wish I knew about your need before today I am stationed at Ft Riley but get up to Kansas City every weekend. I will make contact with you if you are at SS but I will also make a time to come see you in Joplin. Bern can vouch for me and my rotary credentials.
DAVE
Old Oct 26, 2011 | 09:46 PM
12 rotor engine is in the back of the truck and we just pulled onto the interstate heading to sevenstock. Should be there Friday morning... Unless we stop at las Vegas and go to pawn stars and try to pawn this thing....
